FP Black/Zero...Is it worth to buy new?
Old May 15, 2019, 09:51 AM
blackline's Avatar
I'm looking to start saving up for a new turbo kit. I've been thinking about the FP black/zero BB(new) or ETS PTE 6466. I don't have a power goal but I would like to get into low 10's and if possible very very high 9's for 1/4mile. The car will have drag tires and supporting mods.
Comparing pricing:
FP
  • FP Black/Zero BB : $2600
  • FP Manifold: $600(Porting, coating, and hardware kit)
  • MV-S Wastegate: $305
  • STM FP SS Downpipe: $600
    • Total: $4105
ETS:
  • Complete single scroll kit w/ 6466 BB: $4880
Is it even worth buying a new FP black/zero kit over the a 6466 kit? or hunting down a used BB black/zero?
Old May 15, 2019, 09:58 AM
I have a client with a 2.2 motor with buschur 272's and ported stock intake manifold that went from a Zero to the ETS twin scroll kit with a 6466, it went from 690whp @43 psi to 750whp at 41psi and less timing on an otherwise identical setup it also made more torque. It also spools a couple hundred rpm faster with the 6446, it makes 400wtq at ~4600rpm instead of closer to 5000. 100% go with the turbo kit.
Old May 15, 2019, 10:00 AM
2006EvoIXer's Avatar
I'd skip FP manifold on their SS turbos. Tubular is way to go to get better flow angles. But when you add up the cost for FP, I'd just skip to 6466 at this point.
Old May 15, 2019, 10:02 AM
blackline's Avatar
Gotcha, good info Thanks!
I should've added:
2.0L built block/head.
Old May 15, 2019, 10:33 AM
Also, you could probably shop around and get a ~5% discount on the ETS setup. Just FYI.
Being a 2.0L, you'll see spool up 500ish rpm's later than a 2.2. But you'll still get the 6466 spooled sooner and make more power.
Old May 16, 2019, 12:40 AM
MR ArcticC's Avatar
Here is an used 6466 ts kit:
https://www.evolutionm.net/forums/market/754014
Old May 16, 2019, 07:56 AM
Originally Posted by MR ArcticC
For a 2.0, I'd look for T3.
Old May 16, 2019, 08:11 AM
And you couldn't be more wrong. Twin scroll is master race if an appropriate A/R housing is available.
Old May 16, 2019, 08:19 AM
blackline's Avatar
I was thinking vband twin scroll
Old May 16, 2019, 08:55 AM
Abacus's Avatar
I'd also recommend a twin scroll ETS kit for street/track duty. Its going to come up a bit sooner and still make good power.
Old May 16, 2019, 09:01 AM
Only Garret makes those housings.
Old May 16, 2019, 11:55 AM
blackline's Avatar
ahhhhhh I see it now. Guess it's going to be the T3 TS kit from ETS.
Old May 16, 2019, 12:04 PM
There is no T3 twinscroll for the 6466. It's T4 divided only, but that's what you need so you're good to go.
Old May 16, 2019, 04:12 PM
blackline's Avatar
Cool beans. Good info!
Old May 16, 2019, 05:07 PM
Do you have links for 2.0 on 6466 T3 and T4 twin scroll with your appropriate A/R? It doesn't sound right logically that a T4 will spool better and make more up top over T3. I dont want to bore everyone with my logical inexperienced engineering thinking. Basically, twin scroll sacrifices top end for better spool up, but with this huge turbo, I don't see any benefit of using 1.0 liters to point flows to help with spool.
