Discussion / Rumors The rumored Mitsubishi Lancer Evolution XI. .What have you heard? What do you think?
Compression numbers on built engine.
Old Apr 29, 2024 | 05:42 PM
Saleemb_IX's Avatar
I did a dry compression test after driving the car for about 35 minutes. These are the numbers I got on the cylinders with the throttle open
#1 126 #2 122 #3 120 #4 120
Mivec head has S2 cams beehive springs & retainers. Block has turbo tuff I beams, and wiseco 1400 HD 8.5:1 pistons
are these normal numbers with mivec, bigger cams, and 8.5:1 pistons? I was expecting higher numbers.
Old Apr 29, 2024 | 06:43 PM
black E's Avatar
Normal for a low compression piston.
My BR built 2.0 (from back in like 2014) has very similar results.
On my X when I ran 10.0:1 pistons it would read 150+ cold lol
Old Apr 30, 2024 | 02:17 PM
Saleemb_IX's Avatar
Okay cool! It had me worried for a second lol thanks for the input.
Old Yesterday | 01:06 PM
GraysonWright's Avatar
Those numbers aren’t surprising given your setup. With 8.5:1 pistons, you’ve already lowered static compression compared to stock, so cranking pressure will naturally drop. Add S2 cams, which usually have more duration and overlap, and you bleed off even more cylinder pressure during cranking. That combination almost always reads lower on a compression gauge.
Simpaii
Nov 23, 2023 05:50 PM
Stinkyevo1
Aug 3, 2015 09:53 AM
batty200
Jul 23, 2014 06:14 AM
JohnnyTSi
Jan 14, 2010 07:54 AM
BLAYZ
Lancer Engine Tech
17
Jul 3, 2009 11:41 AM
