South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
kevin d tune
Old Mar 10, 2008 | 07:56 PM
  #61
KevinD's Avatar
what dyno was that on?
Old Mar 10, 2008 | 07:57 PM
  #62
nikkadanny's Avatar
348/340 with meth?
Old Mar 11, 2008 | 06:20 AM
  #63
mt057's Avatar
It was on a dyno jet up at alamo. That was with meth at 29 psi. My power band is pretty broad. With out the cams, gears, meth, & hard pipes I made only 284 whp spike.
Old Mar 11, 2008 | 07:12 AM
  #64
nikkadanny's Avatar
power seems kinda of low for a dynojet, but i hear alamo's dyno suck
Old Mar 11, 2008 | 07:19 AM
  #65
Levar's Avatar
Veteran: Army
Originally Posted by nikkadanny
348/340 with meth?
That's pretty impressive. I bet the methanol and Green combination is just sick!
Old Mar 11, 2008 | 07:29 AM
  #66
KevinD's Avatar
damn, thats pretty good for stock turbo (9.8hotside none-the-less). i made 310whp on alamos dyno back in the day when turbo trix tuned my car. that was with cams, TBE, MBC, FP, intake. so i would say thats right on then... approx 64whp increase for the meth, and a cams. not bad at all.
oh and alamos dynojet doesn't really compare to anything.... hahaha. but sense he had a baseline on the same dyno its something to compare against.
Old Mar 11, 2008 | 07:33 AM
  #67
mt057's Avatar
That is w/ the stock 9.8 hotside 16g. I have 57000 mi on it and it doesnt want to boost any higher I wonder if its the o2 housing. I get peak torque at about 3750. I hold 300+ wtq from 3750ish to 6000 (320 till 5500) . I hold 330+ whp from 5500 to 7500. Before I only made 250 from 5500 to 7500 w/ 21psi tbe, mbc, cone filter, mild tune from a different tuner. I am still having problems with the scanner I will post my dyno sheet asap.
