South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
Test Pipe vs High Flow Cat vs State Inspection
Old Nov 23, 2008 | 06:41 AM
JDW1479's Avatar
Everyone,
I'm gonna be purchasing an exhaust soon, with either a high flow cat or a test pipe. I know there is more horsepower gains with a test pipe than a high flow cat, but is it worth the headache of taking the test pipe off everytime you have to get your car inspected?
So my real questions are:
If I do get a test pipe, and have KevinD tune the car with the test pipe on it, will the car act rough if I put back on the stock catalytic converter to past the yearly state car inspection (of course I would re-install the test pipe back once I have pass the inspection)? Or should I just go with a high flow cat and not have to worry about it? What is normally the horsepower difference between the high flow cat and a test pipe?
Thoughts?
Old Nov 23, 2008 | 10:02 AM
goofygrin's Avatar
Here in texas they are going to obdii inspect you so as long as the system is ready and not throwing code you are ok.
This applies for both test pipes and hfcs.
More than hp gains, the test pipe is much louder than a hfc inside the cabin. Typically a testpipe is worth 20hp or so. A hfc is worth 10-15 (depending if metal or ceramic).
Old Nov 23, 2008 | 10:14 AM
bluebanana23's Avatar
Test pipe or hfc are both illegal. I personally went with the hfc to lessen the pollution and noise while ensuring no cels.
Old Nov 23, 2008 | 10:18 AM
OwnedEvo10's Avatar
I went with a test pipe and throw no codes.. I just put the stock cat back on for inspection.. Had no problems with the car running different with the stock cat back on.. Very simple to change out.. Just my .02cents
Old Nov 23, 2008 | 10:22 AM
slvrr's Avatar
I personally wouldn't bother with the hfc. When I had my HKS with test pipe there was hardly any cabin noise. However with my Buschur bullet tbe there is alot of noise evry where inside and outside You will most likely not pass inspection with a hfc anyway. Just do the test pipe it will be worth it plus the people behind you will appreciate the gas high anyway!!
Old Nov 23, 2008 | 10:30 AM
OwnedEvo10's Avatar
^^ hahahaha so true...I love the gas high behind my buddys suby lol...
Old Nov 23, 2008 | 12:07 PM
nikkadanny's Avatar
find yourself a ghetto shop and become friends with them and they will hook u up with a sticker
Old Nov 23, 2008 | 09:44 PM
red evo8's Avatar
sadly last time i went for inspection i said screw it and put my stock cat back on then took it off soon after, its only once a year right?
Old Nov 23, 2008 | 09:58 PM
JDW1479's Avatar
^ true, but I think there are some people out there that can help a brotha out when it comes to inspection time.
Old Nov 23, 2008 | 10:02 PM
booster9's Avatar
im a certified vehicle state inspector
just order a cel cheat that is an extension to where the O2 sensor goes in.. my car passed with a test pipe..
some places are gay and actually look under the car.. i do look, but i never actualllly look lol.. hope the government dosnt find this and get me in trouble!
Old Nov 24, 2008 | 06:29 AM
goofygrin's Avatar
If he gets a good test pipe (like the UR) he won't need the o2 sensor extension.
Of course my HFC needed it and because of me, UR changed the design of the HFC to not need to o2 sensor extension.
Nice.
Old Nov 24, 2008 | 07:13 AM
Lancerguy'03's Avatar
just beware that some shops will do a visual inspection....just talk to shop that you goto....ask them how strict they are..
Old Nov 24, 2008 | 07:24 AM
MSP608's Avatar
I didn't really read through this thread, but is your inspection visual or do they test the exhaust too? If it's just visual get a test pipe and weld a heat shield around it. Works for me and my Dad's cars and we're both catless.
Old Nov 24, 2008 | 07:35 AM
goofygrin's Avatar
Here they do a "visual" and a hook up to the computer to make sure it thinks it's working fine.
Old Nov 24, 2008 | 09:27 AM
MSP608's Avatar
So a heat shield and CEL fix should have you on your way.
