South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
Dyno Results from MZM
Old Sep 28, 2003 | 01:34 PM
EVO Rosso's Avatar
I went down to MZM late Saturday morning and meet up with QAT-R and runny_yolk. Although there were a couple other EVOs owners we are the only ones to represent on the dyno.
The Results:
runny_yolk -- stock -- 213.7 @ 6500 HP / 225.4 @ 4000 TRQ
QAT-R -- AMS Catback, ??? -- 212.8 @ 6500 HP / 224.9 @ 3500 TRQ
EVO Rosso -- Vishnu Standard Turbo-Back -- 236.2 @ 6500 HP / 242.5 TRQ
MZM is a great shop and I will be setting up an Austin EVO dyno day in late October. Their Mustang Dyno is very nice and unfortunately it is not the same spec as FIS in Dallas. The numbers seem much lower than FIS even though it was hotter when I was at FIS on July 12th. Here we the results from that day.
Evo Rosso - Stock - 242.1@6500 HP / 242.0@4000 TRQ
EvoRevo - Stock - 238.4@6250 HP / 235.5@3750 TRQ
ImportPePe - Stock - 227.9@6250 HP / 230.1@4000 TRQ
tx evo - Modified - Works 93 oct ECU reflash - 255.5@6750 HP / 235.3@4250 TRQ
okijack - Modified - 3" UR Turbo Back, Grounding Kit - 246.8@6250 HP / 246.6@4000 TRQ
SILVER SURFER - Modified - 253.6@6250 HP / 252.4@4000 TRQ
Anyway it was fun to meet some local EVO owners and it was nice of MZM to give me a t-shirt for the top dyno of the day for an EVO. I highly doubt I will ever win again but it was fun...
Updated:
Here is my dyno sheet from MZM:
On thing I noticed is MZM didn't rev my car all the way to redline. Notice how it stopped short of my FIS dyno run. I also noticed the weights are different. In any case I don't think these dynos are comparible.
Here is my dyno sheet from FIS:
Old Sep 28, 2003 | 08:22 PM
runny_yolk's Avatar
Hey, it was good to meet everyone and I had a good time at dyno day. We should organize another Austin meet sometime.
Old Sep 28, 2003 | 08:30 PM
evo8urlunch's Avatar
Bill, that is interesting that they didn't take your car to redline...unless at redline you are actually losing power!
One thing I was wondering is if your tach matched the dyno rpm's. I've taken my car up to about 7800 rpm's and didn't hit the rev limiter. Have you by any chance hit your rev limiter? I would love to know at what point our cars begin losing power and if our tachs are off quite a bit.
Old Sep 28, 2003 | 08:35 PM
02izzel's Avatar
good post. nice numbers.
Old Sep 29, 2003 | 07:39 AM
runny_yolk's Avatar
Yeah, I noticed that about my dyno sheet as well. One possibility is that they didn't want to bump against the rev limiter so they let off early? Not sure what's up with that (I might call them later to ask). Btw, these were 1:1 4th gear pulls.
As far as the rpms, they asked us to remove our timing covers on our engines so they could clip onto the wire in our engine bay. My guess is that these rpms are based on engine revs and not dyno revs.
Old Sep 29, 2003 | 12:33 PM
blitzbaster's Avatar
damn guys I wish I could have gone, but I had work on sat. I actually went on friday to run on the dyno. I pulled 229.2whp @6250 RPM and 243.1tq@3750 RPM, this was stock btw. I was suprised how high my tq was. Next time you guys do this I will definately take off work. Plus I will have a few goodies to dyno with.
Old Sep 29, 2003 | 01:35 PM
USP45's Avatar
That is too bad they did not run it up a little more, it looks like the HP was still climbing. The new curve looks much more smooth than the old, I am somewhat curious as to the difference in the two Mustang Dyno's. You will go back once you have the Xede and the cam gears on I would think?
Old Sep 29, 2003 | 03:54 PM
EVO Rosso's Avatar
OK, I found out why the two dynos don't match. My dyno from FIS was in 3rd gear and my dyno from MZM was in 4th gear. This would explain the massive differences between the two.
I will be heading back again in late Oct with the full Stage 1 installed.
Old Sep 29, 2003 | 09:59 PM
Yea evo roso is correct. The numbers can vary because of which gear you use.
EVO Rosso
South Region
35
Oct 29, 2003 07:12 AM
cokex
South Region
Sep 26, 2003 04:14 PM
EVO Rosso
South Region
37
Aug 6, 2003 02:56 PM
EVO Rosso
South Region
30
Jul 10, 2003 11:05 PM
tx evo
South Region
Jul 4, 2003 09:01 PM
