TEMEVO/SFL
Old Jan 25, 2008 | 06:05 PM
  #40561
Slick-IX's Avatar
^ i think thats what jeff has
Old Jan 25, 2008 | 06:20 PM
  #40562
FLOW1's Avatar
Slick, send me a pm bro.
Old Jan 25, 2008 | 07:16 PM
  #40563
Evoryder's Avatar
Originally Posted by Slick-IX
jdm rear ftw.
yo jeff i might have to question you about the meth... expenses, install, and maintenance... ive heard stock and meth is a sweet combo lol
~METHANOL 101~
Installation: Free if you do it yourself or with a friend
Maintenance: Inspect pump once a year, make sure fittings aren't leaking
Expenses: purchasing a 5Gal drum of meth once or twice a month and wasting more gas seeing that your new found power will creat an urge to hit it.
Tuning: Needs to be tuned properly for both safety and optimum power
Safety: Inspect meth to make sure it's not contaminated. Make sure your pump works and you have a good Fails Safe system.
FailSafe: Customize a failsafe. Add components from leading companies eg Zeitronix, Aquamist, Labonte.
Knowledge: Understand how meth works, how it affects your motor and what damage it can cause from abuse.
yes it is sweet with the stock turb.. I'm on a smaller hotside than you guys and the car pulls like a monster. I'm at 30psi on the stocker.
Originally Posted by Profoxcg
the fireball thing sound sweet, I think i want it, can use a stock turbo w it?
R u serious or do you really think think like this? Fast n furious mind set?
YEs you can run meth on the stock turbo. I wouldn't waste my time with meth unless you're going to run a 26+psi of boost.
Old Jan 25, 2008 | 07:36 PM
  #40564
Slick-IX's Avatar
how expensive is it? not the kit, but the meth itself?
Old Jan 25, 2008 | 07:43 PM
  #40565
VenomEVO8's Avatar
Originally Posted by Evo Girlie
I sleep at 10 already
well then 9 will be easy for you
Old Jan 25, 2008 | 07:48 PM
  #40566
VenomEVO8's Avatar
http://s5.photobucket.com/albums/y17...t=MOV03072.flv
see if this link works.. this is eddys car ... put down 380 whp and 420tq.. PLUS FLAME
Old Jan 25, 2008 | 10:06 PM
  #40567
Profoxcg's Avatar
^ cool crazy ! that is a little too much fire lol.
Old Jan 25, 2008 | 11:30 PM
  #40568
Evoryder's Avatar
$43 bux for 5gals. You can find it cheaper if you search and call around...
Old Jan 26, 2008 | 05:25 AM
  #40569
VenomEVO8's Avatar
Well thats 100% meth...
Old Jan 26, 2008 | 06:09 AM
  #40570
Slick-IX's Avatar
so running 100% meth how long does it last you lol
Old Jan 26, 2008 | 08:50 AM
  #40571
Evoryder's Avatar
about a month and change
Old Jan 26, 2008 | 09:05 AM
  #40572
Profoxcg's Avatar
so you run 100% meth and it last you about a month? do you not drive much?
because I waste about $200 in gas...
can you clarify things?
Old Jan 26, 2008 | 09:41 AM
  #40573
Evoryder's Avatar
u didn't do your research.
Gas = 14gal vs 5gal of meth
Gas is always being used up vs meth only when you go WOT(i know you don't drive WOT all the time)
100% meth = percentage of meth. SOme run 50/50(50%meth 50%distilled water) or some just run 100% distilled water.
My meth doesn't spray till 15psi. Anything below 15psi there is no meth.
Make sense?
Old Jan 26, 2008 | 10:24 AM
  #40574
VenomEVO8's Avatar
Make sense?
I was just going to say that.. its set to 15 or 16 psi to activate...
Jeff- have you heard anyone running 75meth 25water???
Old Jan 26, 2008 | 11:13 AM
  #40575
Profoxcg's Avatar
Make sense?
Oh cool, yes i t does. so basically in openloop after 15PSI you stop using gasoline? and just switch to meth and h2o? or is there still gasoline in the mix?
