TEMEVO/SFL
Old Apr 28, 2009 | 08:47 PM
  #44311
Evoryder's Avatar
^ more noise when you rev, when driving? does the humming change? Is this something constant or happens after long drives?
Old Apr 29, 2009 | 06:04 AM
  #44312
Gators2001's Avatar
Did u check the shaft?
Fuel pump sounds like an electric motor hmm. is that it?
Old Apr 29, 2009 | 07:26 AM
  #44313
A so me go's Avatar
Originally Posted by Evo Girlie
i'll have my injen uicp, intake n apexi filter up for grabs soon. The uicp is tapped for Meth but can be screw shut it's small opening
Are you putting car back to stock to sell it ?
Old Apr 29, 2009 | 07:51 AM
  #44314
Evo Girlie's Avatar
i'm not selling the car just changing some parts. I already decided no1 will give me what the car is worth. it's so close to being paid off that it will become simply my fun car no more daily .
Old Apr 29, 2009 | 09:44 AM
  #44315
Bizo2's Avatar
sounds is louder when the car is in idle,
it starts right after i start the engine
Old Apr 29, 2009 | 10:17 AM
  #44316
Bizo2's Avatar
i took the back seat out, and i think its coming from the fuel pump
Old Apr 29, 2009 | 10:20 AM
  #44317
Evo Girlie's Avatar
^ the fuel pump will whine forever and when it's cold out even more. It whines more on idle or when u punch it hard. Is it like a whistle sound??? if so get used to it cuz it def won't go away lol
Old Apr 29, 2009 | 11:08 AM
  #44318
Bizo2's Avatar
have no prob with that, just hopng is nothing else
Old Apr 29, 2009 | 11:29 AM
  #44319
Evo Girlie's Avatar
if it started after u installed the fuel pump that is what it is. The car drives fine otherwise?? no weird shifting or anything?
Old Apr 29, 2009 | 01:38 PM
  #44320
Gators2001's Avatar
to pump should turn on even with the car off.
Old Apr 29, 2009 | 01:44 PM
  #44321
Gators2001's Avatar
the pump should turn on even with the engine off.
Old Apr 29, 2009 | 05:00 PM
  #44322
Evoryder's Avatar
also could be driveshaft bushings.
Old Apr 29, 2009 | 05:17 PM
  #44323
diablo2184's Avatar
where would you guys get your cylinder heads worked on? send it out to headgames, ams, etc? local? DIY?
Old Apr 29, 2009 | 08:03 PM
  #44324
Gators2001's Avatar
I did my Z's up in BOCA. The works, 5 way vavle job and all. pm if u want info.
Old Apr 30, 2009 | 10:27 AM
  #44325
Bizo2's Avatar
car drives fine, no gear problems.
would i hear any noise coming from the driveshaft or bushing while the car is in idle
