TEMEVO/SFL
Old Mar 2, 2005 | 12:52 PM
  #13351
Turbo-Ron's Avatar
Mitsubishi Motors launches Lancer Evolution IX hi-performance 4WD sports sedan
Lancer Evolution IX
Tokyo, March 2, 2005 — Mitsubishi Motors Corporation (MMC) today announced that the Lancer Evolution IX high-performance 4WD sports sedan would go on sale at affiliated dealerships throughout Japan on March 3, 2005. With a 2.0-liter intercooler-turbocharged engine powering all four wheels through an electronically controlled 4WD system, Evolution IX raises all dynamic performance parameters to a new level. Tax inclusive prices range from 2,940,000 yen to 3,570,000 yen.
Evolution IX marks the 12th model in the series, which has also included an automatic transmission model, since the Lancer Evolution debuted in October 1992. Major features distinguishing the latest model include the adoption of Mitsubishi's proprietary MIVEC*1 variable valve timing technology in the intake system and improvements to the turbocharger that result in higher torque and produce better response for improved engine performance across its full rev range. New front and rear bumpers bring both high aerodynamics and cooling performance.
Evolution IX is offered in three trim levels. The flagship GSR grade features Mitsubishi Motors' cutting-edge ACD*2 + Super AYC*3 + Sports ABS*4 electronically controlled all-wheel control component system and a 6-speed manual gearbox. The motorsport-specification RS uses a special lightweight body, a new titanium-magnesium turbocharger, 5-speed gearbox and ACD + mechanical rear LSD all-wheel control. New for Evolution IX is the GT grade that brings together RS's turbocharger and drivetrain specification and GSR's comfort-bias body with its enhanced sound deadening. Allowing owners to customize their Evolution IX's to individual needs and preferences, a comprehensive range of factory- and dealer-fitted options as well as Ralliart tuning and dress up parts are available.
I . Product features
1. Exterior
In an integral molding, the new front bumper houses an oversize mesh grille to raise engine cooling efficiency and also locates the Mitsubishi 3-diamond emblem. All unnecessary openings on the undersurface of the bumper have been closed off to reduce air resistance.
The new rear bumper features a diffuser undersurface in a distinctive design that shapes the corners to stabilize air flow detachment and reduce drag and that adds to Evolution's sedan-racer looks.
The rear wing assembly uses molded vertical components color-keyed to the body and a carbon-fiber hollow spoiler that lowers the center of gravity.
Dark-clear extensions on headlamps and rear lamps enhance the car's premium appearance.
GSR and GT trim levels run on Enkei 17x8JJ lightweight 5-double-spoke alloy road wheels that are 0.15 kg per wheel lighter than those fitted to Evolution VIII MR.
Evolution IX is available with a new air dam extension and rear wing Gurney flap (dealer options) that further improve aero efficiency. These advanced aero devices improve high-speed handling and stability by reducing front and rear wheel lift and enhancing the front-rear aero balance.
2. Interior
Dashboard ornamentation on GSR and GT models is clear coated with a rich carbon-like finish.
GSR and GT models use new alloy accelerator, brake and clutch pedals designed for sport driving as well as to accent the sedan-racer look to the cockpit.
GSR uses Recaro bucket seats. The squab facing uses non-slip Alcantara suede upholstery that keeps the occupant fresh and comfortable even on longer journeys while the side bolster facings are covered in genuine leather making the seats easier to get in and out of and also adding a touch of choice luxury to the interior.
GSR is equipped with a carbon shifter panel embellished with the Lancer Evolution logo.
GSR and GT models use a high-density dash silencer and double-sealing weatherstrips that reduce interior noise levels.
3. Engine & transmission
For Evolution IX the 4G63 engine gains Mitsubishi's MIVEC variable valve timing technology that improves top-end output as well as fuel efficiency. MIVEC technology allows GSR to return 10.0 km/l in the Japanese 10-15 mode driving cycle, equivalent to a three percent improvement in mileage.
On GSR, the turbocharger uses a lengthened diffuser to generate more low-end and mid-range torque (400 N-m(40.8 kg-m)/3000rpm) as well as bring a significant improvement in response (average 5%) across the full rev range.
On the RS and GT, the turbocharger compressor wheel uses magnesium alloy instead of aluminum alloy. This brings a dramatic improvement in supercharging response. Mated to a 5-speed gearbox with higher torque capacity, the engine has been tuned to generate maximum torque of 407 N-m(41.5 kg-m)/3000rpm.
The 5-speed transmission used on the RS and GT derives from the close-ratio competition gearbox but has a revised top gear ratio for improved high-speed cruising.
4. Other features
New rear springs lower vehicle height slightly, improving rear end stability (GSR and GT) and allowing the Super AYC to operate more effectively and improve steering response (GSR).
Features retained on Evolution IX include: Evolution's well-proven lightweight and high rigidity body featuring the aluminum roof panel pioneered on Evolution VIII MR (all grades); jointly-developed Bilstein hi-response shock absorbers (GSR and GT); Mitsubishi's ACD + Super AYC + Sports ABS electronically controlled all-wheel control system (GSR); and Brembo ventilated disc brakes (GSR and GT).
*1: Mitsubishi Innovative Valve timing Electronic Control system
*2: ACD (Active Center Differential)
The ACD incorporates an electronically controlled hydraulic multi-plate clutch. An ECU optimizes clutch cover clamp load for different driving conditions, regulating the differential limiting action between free and locked states. The result is improved steering response together with better traction. ACD provides three modes — Tarmac / Gravel / Snow — to enable quicker control response for changes in road surface. A single ECU provides integrated management of both ACD and Super AYC components.
*3: Super AYC (Active Yaw Control)
Mitsubishi's Active Yaw Control system uses a torque-transfer mechanism in the rear differential. Under ECU control, the system operates to raise cornering performance by transferring torque between the rear wheels as dictated by driving conditions and so control the yaw moment acting on the car body. In an evolutionary step, switching from the use of a bevel to a planetary gear differential gave Super AYC the ability to transfer almost twice the torque between the rear wheels. As well as reducing understeer further, it delivers LSD-level traction. The use of a single ECU to integrally manage Super AYC with the ACD results in a synergism that makes both components operate more effectively than if they were under independent control.
*4: Sport ABS braking
The system ECU uses information from a steering angle sensor that detects steering inputs as well as from lateral G and vehicle speed sensors to apportion pressure to each of the four wheels independently. The result is improved steering response under braking. Mitsubishi's Electronic Brake Force Distribution (EBD) system, integral with Sports ABS, optimizes allocation of braking force between the front and rear wheels. Increasing the pressure applied to the rear wheels when braking close to the limit, EBD reduces the load on the front wheels to realize better anti-fade performance. The system also compensates for changes in surface and vehicle load conditions to ensure predictable and consistent stopping performance at all times.
II . Sales information
1. Sales target: 5,000 units
2. Available at: MMC affiliated dealerships throughout Japan
3. Manufacturers Recommended Retail Price (nationwide, yen)
Trim level Engine Transmission Drivetrain MRRP
Ex-tax Tax inclusive
GSR 2.0-liter
4-cylinder DOHC
16-valve MIVEC
with intercooler -
turbocharger 6M/T Full-time
electronically
controlled
4WD 3,400,000 3,570,000
GT 5M/T Full-time 4WD 3,160,000 3,318,000
RS 2,800,000 2,940,000
  #13352
MephistoKnight's Avatar
Originally Posted by Dr Evo
Oh here is this month's regular feature from Dr. EVO for the month of March.
C'mon trini bwoy, yuh haffi reach 1000 quick my yute
Old Mar 2, 2005 | 12:53 PM
  #13353
Originally Posted by TheGVR4kid
But boy can she pop n lock.
talkabout talent
Old Mar 2, 2005 | 12:58 PM
  #13354
Lancer Evolution IX
1. Exterior
2. Interior
4. Other features
GSR 2.0-liter
4-cylinder DOHC
16-valve MIVEC
with intercooler -
electronically
controlled
Nice read, but will it get over here, that is the big ?
Old Mar 2, 2005 | 01:20 PM
  #13355
PRVRT's Avatar
Damn, Meph!! Stay off the caffine or the crack!!!
Old Mar 2, 2005 | 01:30 PM
  #13356
PRVRT's Avatar
Exclamation
ONLY 4 DAYS LEFT!!!!
***TEMEVO Family Day***It's official now we have a picnic on Sun. March 6 at C.B.Smith Park in Pembroke Pines on the NW corner of Flamingo & Pines Blvd. (entrance on Flamingo rd.) at
shelter # 14.
Waterslides & Tube rides are open so bring your swimsuits.
Park hours are 8:00 am - 6:00 pm.
I reserved a medium shelter (they were out of large) that
can hold 50 people.
They have grills, water and electricity. Please pick something you want to bring for food! Please post up!!!
your family and your car
hamburgers and buns
hotdog and buns
potato chips(doritos, cheetos, pringles, etc. please post what brand you are bringing)
beer(please post what brand you are bringing)
desserts(cakes, pies,etc.)
knives, forks and spoons
cups
sodas
juice
water
ice
snacks (remember kids are going)
any native dish, from your respective country, you wish to bring(please bring enough for alot of ppl)
fried chicken(if you want too)
napkins
charchol
bbq grill
cameras
salads
bread
coffee
games to play(footballs, baseball and gloves,etc)
any other things you can think of please post
____________________________________________
Dr Evo - Chicken Wings
DR.MR - Beck's Beer and Kid snacks!!!
Elemental Evo -
EVO_ATE_U -
fastmarsh-
gabesir - Ice and water
gtlimer/Ms. Evo -
Jonasan50 -
LoboEvo - Gatorade, Sodas (Sprite, Coke, etc......)
Mephisto Knight -
PRVRT - Plates, potato Chips(assorted), Water, eating utensils, Napkins
Rudy -
Scooter & Lady B. - Sloppy Joe (Lady B. Style)
speed kills -
Turbo Ron -
vertGST -
VWRyder -
Old Mar 2, 2005 | 01:31 PM
  #13357
PRVRT's Avatar
Originally Posted by Jonasan50
Whats up Beeotches!! Im up in Orlando chillin with the family... We've been hittin all the parks and having a good time.. Finally a vacation away from all the sh-theads at the mall... Miss you guys... Feels like I haven't seen you all in ages.. I saw Ahsan yesterday.. That boy just don't stop workin... I drove his EVO... Man it felt sooo good to be back behind the wheel of an EVO.. Slow or not!! I miss my baby... Lots of nice weather up here.. Cold as a mother at night.. The EVO's would love it!!! What's new with you guys, other than turning our forum into an autocross delight.... I'm gettin ready to head over to MGM studios.. I'm gonna see how many times I can go on the rockin roller coaster before I throw up!!! What do you say Element??!! 10-15 times before I start to get sick??!! Puss... I love the beginning of the ride where it shoots you to 60 in 2 1/2 seconds... Feels like I'm drivin the EVO when it takes off!!! Lots of beautiful British women at my resort.. Hard to contain one's self!! I better get going before the wife starts sending out a search party for me!!! Peace out brutha's..!!! John...
Oh yeah,
Cracker *** cracka's!!!!
So i was right when i said that Ashan was crackin' that rib again!!!!!
Good to see you are having fun!!!! Are you going to try to make it to the Family Day???
Old Mar 2, 2005 | 01:36 PM
  #13358
PRVRT's Avatar
Exclamation
Yeah ron, but i don't believe that sometimes becasue what goes on in Japan might not what we get here!!! So I would be on the look out for something from the MMA! And than we will see what happens from there! Thinking about getting one???
Old Mar 2, 2005 | 05:13 PM
  #13359
No man!!! I am on a natural high
Old Mar 2, 2005 | 06:26 PM
  #13360
Old Mar 2, 2005 | 07:13 PM
  #13361
Old Mar 2, 2005 | 07:54 PM
  #13362
dr.mr's Avatar
Originally Posted by Scooter
Lobo - 2 Silver... Got it!
Elemental - 2 sets? Total of 4 in Pink???
Doc Evo - Could you resend that image in something not mimed... I hate MIME... AOL software says it decodes mime automatically, but that is bull...
Anybody else for stickers??? Tonight is the deadline for ordering!!
Vegasboy301 - Nice of you to visit...
Oh well, lots of work today and two job interviews...
Scooter, I need two stickers in MR - Gray.
Old Mar 3, 2005 | 03:33 AM
  #13363
LoboEvo's Avatar
Morning everyone!
Old Mar 3, 2005 | 04:57 AM
  #13364
TheGVR4kid's Avatar
Just another day in paradise...
Hello das Scooter
Old Mar 3, 2005 | 04:58 AM
  #13365
Scooter's Avatar
Originally Posted by LoboEvo
Morning everyone!
Goofy Morning all.
Don't worry Dr Mr I already had yours and Brads on my list at home. (It is brad, right? It's the alheimers kicking in again. )
Yeah Lobo, I got your two silvers.
