Charleston EVO'S!!!!!!
Old Jun 9, 2006 | 05:52 PM
Tpayne84's Avatar
I need HELP!!
I just had some Cams, MBC, BOV, LICP ect...... installed at GSC. on my way home my car died. I thought it was loose IC piping but it wasnt..... it turned out that my intake heat shield cut through some wires, all that is fixed now but the car still wont start so were thinking now that it may have fried my ECU. does ANYONE have a ECU that i could swap out in my car for 2 sec. to trouble shoot at GSC tomorrow morning-ish??
I could meet you there and do the swap. It would only take 2 min of your time. i just need to know if my ECU is the problem or not.
Give me a call if you can help
843-209-5975- Tyler
Old Jun 12, 2006 | 01:42 PM
C6C6CH3vo's Avatar
What intake heat shield do you talk of that chaffed into the wires? Is it an OEM part, aftermarket, or DIY?
Old Jun 12, 2006 | 05:08 PM
BADEVO's Avatar
TPayne - I talked to Greg and I can swing by and check it out for you. I have an 03.
Old Jun 13, 2006 | 05:00 PM
Tpayne84's Avatar
It was the typhoon one that came with the car when i bought it. It pinned the wires against battery, and aparently carbon fiber is a conductor and it grounded the wires and may have rosted the ECU. i would have switched intakes but i no problems with it.
Just a bad stream of luck im having i guess.
Old Jun 13, 2006 | 07:06 PM
C6C6CH3vo's Avatar
Any recent news?
If the ecu is good and you need someone to check the wiring I have a meter and contrary to the popular belief Elen can troubleshoot wiring.
Old Jun 17, 2006 | 04:10 AM
geminibby's Avatar
sounds like a common theme for our evos recently (nothing to do with GSC). I think i just blew my head gasket, 8thwonder's clutch just went out.
Old Jun 18, 2006 | 12:32 PM
Tpayne84's Avatar
Any recent news?
Well i got a call from mitsu yesterday and they said that it is infact my ECU. i have on on its way and it should be here soon. Hopefully that the problem and she starts up.
Old Jun 18, 2006 | 04:52 PM
BADEVO's Avatar
I went by GSC the other day, but your car was gone.
Old Jun 23, 2006 | 05:38 AM
geminibby's Avatar
did they warranty it? Just kinda curious.
turbocheese
16
Nov 19, 2015 09:16 AM
TechyEVO
May 18, 2015 12:43 PM
SyHS
Sep 20, 2014 02:01 PM
clanzkiller
24
Jun 15, 2014 03:33 AM
jayspec718
Mar 12, 2014 04:05 PM
