TTP Tuning Trip to NC...
haha .... good point.
your log and my log actually are almost dead on for numbers.... i did mine this morning at 385/340 i think yours was 389 and 345 or close to it... i figure knowing that your car is probably still faster than mine even though we are modded almost the same, a 10hp 10tq difference is pretty close to correct. matt55's numbers ?
my only concern for tomorrow is how my car is going to react to false knock with the balance being off inside the motor. the car vibrates like a sob at high rpm when i did a fun run out by the house here. she still rips though..........
did you log it ? were you seeing knock ? during the tune, there wasnt any at all.... so hopefully nothing has changed.... if the balance is off, meaning the oil pump sprocket or whatever it is you want to call that one... it would actually only take us about 2 or 3 hours to fix it. Just let me know if you want to do it
no pump gas runs ?... id love to see what you do on pump as well.... you have all night to nail the tune on racegas.... if you want, you can run a few pump runs, we can go for a cruise with the racegas in and i will help you log it and you can adjust it how you want and we can come back to the track and you can fine tune it for the track
ok, just for you cupcake
i would'nt mind seeing how it does on pump either. so, i'll go pick up some racegas, go to H&H and swap out the tranny fluid, pill removal and clutch line. as long as i can get outta work early tomorrow. i'll give you a call.......
im jumping in the a.m...... heading to WAMC and then to the house.... so if they cant do it there, you are welcome to come here as well. fluid is about 20 minutes if that, clutch line, maybe 45, the pill is simple if i remember right.
7-11 you still fail
