Camp Lejeune/Jacksonville Evos
True...if you need them more...It's pretty easy once you do it...I took my time on the drivers side (I did it first), then the Pass. side went quick. Biggest pain is the lower strut bolts that are tightened to 123 ft/lbs...without an impact wrench they're a little stubborn to break loose.
yeah... i still dont know how to get ahold of him... but his wife is really good friends with a female friend of mine and i am going down with her really soon to visit and surprise him... But i figured while i was down i might as well check some of you guys out.
oh billy you can check me out antime...yeeeeeah!....we need to get our little "meet" started back up down here though, its been a while. car looks good bob, im liking it...now go put that ETS order in.hahaha
Just got back from the Mitsu dealer, where I had them take a look at my faded caliper. It was covered under warrenty and I will receive my new one this thurday. Just wanted to pass that along to everyone. It's covered under the 3yr/36k. Hopefully none of you have this problem though.
Well about getting together again, I'm down for the same time and place. I'll leave that up to you guys.
Also just swapped out map sensor and now logging boost. Everything is looking good, except my slow spool. Working on that!!
I don't think so. I think omly certin things are covered for a certin period of time. I know the powertrain is covered until then but I think the caliper stop being cover after 3yrs or 36k. I can ask for you when I go there on Thrusday, better yet you can call Mitsu America and they should be able to tell you. That's where I found out about the calipers.
Jason I'm going to put on my wastegate today and see if that might help with it a little. Anything I should know before install?
Good to hear they covered the caliper!...Yeah we gotta sync up...I wanna get some logs of my car. I think I may have a plug going bad, or is already bad. At cruising speed, the car will sputter...just one quick time, I can see it on the wideband...I suppose I could just pull them and have a look see...Hit me up if you need a hand with the wastegate...or just want someone to bs with...
im painting mine silver with black brembo
