Camp Lejeune/Jacksonville Evos
Sure, see what they will want for it. I imagine it's going to be pricey. I grabbed one for the TL off ebay for $65 shipped which was luck and a steal. It was still sealed in the plastic from the dealer.
$65, damn right you got lucky on that one. Them damn books are usually high dollar.
Yeah, It was a deal where the guy ordered one and it got "lost" so he bought another then the original showed up. Honestly, it's so detailed it's crazy. If I end up living up here where the car is going to be garaged for a couple months through the winter, I may have my hand at a full build by myself. It's not rocket science and will be an awesome learning experience. Plus TRE is right down the road which is kind of sweet if I ever talk myself into doing a 5 speed swap.
I have been looking for a shop to install some parts and tune my X. Everyone pointed to Force Performance. I called Majestic Motorsports(known for building Surpas), just to see if by chance they had a AWD dyno. They told me they do have one but they dont have the front rollers hooked up yet. That they will be ready for the first of the year. So, to save me a 3 hour trip, Im gonna have them install the rest of my parts and tune my car. They build some of the fastest Supras in the nation, so I figure why not see what they can do with an AWD car. Im planning/hoping on getting everything done in Febuary.
I think some of the locals can probably take care of you and save you quite a bit of cash in the long run. I'd definitely not mind doing the tune and installs. I need to get some more cash for my build when i get to it
I'm also buying the IAC from the totaled IX in Fayetteville. So I might have that swapped out next week also.
Well, I DO have an rear o2 sensor. I think I found the problem with the P0138 code. The black wire that comes out of the o2 Simulator is missing it's ground. That should be an easy fix. When I get a BR TBE I'll do the spark plug anti-fouler fix. Do you need 2 or can you just use one anti-fouler?
Instead of running an O2 simulator why don't you just have the rear o2 turned off in the ECU. It doesn't do anything anyways. I run one anti fouler on mine but it's the longer one. If you run the short ones you will probably need two.
