Camp Lejeune/Jacksonville Evos
Old Feb 5, 2008 | 05:31 PM
  #616
crewdawg130's Avatar
Originally Posted by MREvolution06
A/F Log
4000-11.4
4500-11.0
5000-10.9
5500/6000-10.7
6500/7000-10.6
On my fuel map 260 load I'm at
4000&4500 - 9.5
5000 - 9.4
5500 - 9.6
6000 - 9.7
6500 - 10.0
7000 - 10.1
260 load and 4000 thru 7000 I had knock. 7 counts dropping to 5. I'm running rich so I have no clue what to do. More fuel or less timing? Any suggestions?
Jason PM me your email addy and I'll send you some logs.
what psi and timing?
Old Feb 5, 2008 | 05:40 PM
  #617
MREvolution06's Avatar
Hitting a max of 24psi dropping to 22psi @ 7000
Timing
4000 - 2.3
4500 - -0.3
5000 - 0.8
5500 - 1.2
6000 - 2.9
6500 - 5.6
7000 - 7.0
Old Feb 5, 2008 | 05:43 PM
  #618
Timing
4000 - 2.3
4500 - -0.3
5000 - 0.8
5500 - 1.2
6000 - 2.9
6500 - 5.6
7000 - 7.0
i know thats what you're login but whats in your map? put them next to those if its easier and sent it to jason
Old Feb 5, 2008 | 06:19 PM
  #619
Sorry about that. I meant to put those down, guess I forgot. Here you go.
4k - 3
45 & 5k - 4
55k - 5
6k - 6
65k - 8
7k - 10
Email send as well.
Old Feb 6, 2008 | 06:01 AM
  #620
bigric09's Avatar
with how rich you are... add some fuel.
4500 + .2
5000 + .3
55 - 60 + .5
see what that does... Id leave your timing alone for now... see what that fuel change does, and turn your boost down to about 23
Old Feb 6, 2008 | 10:10 AM
  #621
4500 + .2
5000 + .3
55 - 60 + .5
I'll try that out and get back to you. Thanks bro!
Old Feb 6, 2008 | 12:35 PM
  #622
ohEVO18's Avatar
sounds like he is referring to BG synchroshift II
Is it really that good? I was considering getting some, but didnt..im gonna need some when I do my clutch so should I get that?
Old Feb 6, 2008 | 01:07 PM
  #623
alicea8541's Avatar
I was actually talking about this.
https://www.evolutionm.net/forums/sh...highlight=blox
Old Feb 6, 2008 | 01:18 PM
  #624
bigric09's Avatar
after seeing what other people experience, i will never use a stiffer mount. You get the same results with a torque dampener and none of the vibration. If its working for you, congrats, but ive seen the other side of the story and it is not happy.
Old Feb 6, 2008 | 01:26 PM
  #625
ohEVO18's Avatar
I knew what ya were talkin bout, i was still curious as to the BG
  #626
bigric09's Avatar
I like it... with how you drive, its perfect. If you were a track 100% type guy id go with something else.... b ut for the driving you do, and power level, its fine
Old Feb 6, 2008 | 01:48 PM
  #627
alicea8541's Avatar
I agree.
Old Feb 6, 2008 | 01:51 PM
  #628
bigric09's Avatar
one thing fo sho, its smooth as hot butter
Old Feb 6, 2008 | 02:12 PM
  #629
Psquared's Avatar
Old Feb 6, 2008 | 05:43 PM
  #630
ohEVO18's Avatar
you're smooth as hot butter bob lmao
