Camp Lejeune/Jacksonville Evos
You know....I was gonna pm you Jason, but didn't know how busy you were, and if you still had your connection with parts.
That is a good option for you Andrew...PM Bigric09 ^^ exactly the setup you are most interested in, and maybe a second...and wait for him to get back to you with a price.
Hey Jason, I forgot to ask....I did a boost leak test on my car..and my stock IX dv starts to leak out the "recirc" side at just around 7lbs??!! Is that normal, or is something wrong? I would assume that's not correct...I pushed up on the seal part, to cycle it up and down and it moves fine...but just starts to leak. It's a minor leak, but it's there none the less...
I bet you would hit the 11's easy with all that metered air vented out!
hahaha I'm pulling my hair out right now surfing lejeune yard sales for a laptop...
AND, now I need to shop around for a recirc-bov. what a pita...
I'm actually going to try to hit up Mitsubishi and claim it is a pos. I don't know if they will replace it with a new stocker...but it's worth a shot.
Either way, if they don't. I'm going to end up going with the Forge RS. I can do a boost leak test on it, and keep tightening it down to hold 26 psi. I wonder if that's what was causing my boost to taper as much as it does....
Finally! I scored a sick toshiba laptop! Dual 1.73ghz processors, 120gig hard drive and 1 gb of memory. Has a super drive with light scribe, 15.4 wxga screen. FOR $400!!!!!!!!!!!!!!!!!! Timing was everything! Vista home premium and the works. It's a little overkill but the price was right....now I need some old school evoscan 1.29a software......acheemmmm...(ben).. ;-)
Some people have issues with the newer versions of it....I don't know why...version 1.29a has worked fine with every operating system/wideband/map sensor...so that's the one I'll go with. I don't feel like having it be temper-mental at the track and not want to work.
