Jax FL Social Thread
Old Mar 4, 2010 | 05:01 PM
  #1576
Fast_Freddie's Avatar
Veteran: Navy
Sounds good with me... I am down for whatever Im not picky... BBQ sounds excellent though!
Old Mar 4, 2010 | 07:07 PM
  #1577
Jk's03EVO's Avatar
I have my physical therapy appointment tomorrow at 11 so probably cant make it. Let me know though. I can probably be over there at 12:45-1:00 if it doesnt run too long.
Old Mar 5, 2010 | 05:25 AM
  #1578
EvoVIIIFL's Avatar
SIr please turn your head and cough...
now bend over (snap of latex glove)
if he's walking funny when you see him guys at least you'll know why
Old Mar 5, 2010 | 06:12 AM
  #1579
LUNARFX's Avatar
So are you guys still going to be hanging out around 6pm? I wasn't even planning on coming by till around then?
Old Mar 5, 2010 | 10:04 AM
  #1580
Jk's03EVO's Avatar
Depending on how long my tire balancing takes, changing spark plugs, O2 sensor, doing the throttle body seals and other stuff we could possibly still be there. I definitely need to clean the car. The neighbors have what seems to be a lotus tree that likes to pollinate the car everyday.
Old Mar 5, 2010 | 06:42 PM
  #1581
Veteran: Navy
Jax peeps, if you wanna caravan to Titan tomorrow we are meeting at the rest area exit 331 between jax and st. augustine right after racetrack road at 7:15am
Old Mar 6, 2010 | 11:29 AM
  #1582
stevodaevo's Avatar
so after 29k and 13months of waiting for my evo to come home, drive only within 2weeks. I found this that caused the destruction of my motor
a few things I like to say was: 1. Improper machining 2. piston to wall clearance was off 3. Tuning sucked
Old Mar 6, 2010 | 02:06 PM
  #1583
TTP Engineering's Avatar
Sucks to hear. Those are very odd looking pistons they look like they are lacking skirt.
We have our Aluminum Rod Race engines in stock for Evo X and ready to go in 9.0:1 compression ratio and 2.0L form. Rated to 9500rpms conservatively. Rated to 800-1000hp.
Let us know if we can help.
Old Mar 6, 2010 | 08:28 PM
  #1584
Jk's03EVO's Avatar
I think I found that problem about the TPS. Yes it's not reading full 100% throttle but why the code is being thrown is the BOV.
https://www.evolutionm.net/forums/ev...-tial-bov.html
But about that oil thing. Yeah driving back after pulling over I figured that the mounts and the downpipe touching the lower brace doesnt help the vibrations that kill the sending units. So I am ordering a relocation kit immediately upon waking up Monday. I am sure it will fix the problem.
Old Mar 7, 2010 | 08:48 PM
  #1585
stevodaevo's Avatar
Thanks for the help, but I need it in 2.35L form not the 2.0L
Old Mar 8, 2010 | 12:31 AM
  #1586
Jk's03EVO's Avatar
Why do you need it stroked? Apparently it didnt work too well.
Old Mar 8, 2010 | 01:48 AM
  #1587
STWHY?'s Avatar
Funny John..You buy a supra..And suprastar buys an evo...Justin
Old Mar 8, 2010 | 04:14 AM
  #1588
Veteran: Navy
Well, that is refreshing news... You should try replacing the line from the BOV straight to the manifold and see if that changes things, if that doesn't work and you need a good recirc BOV I know where you can get one that is lightly used, Synapse synchronic with the Tial flange so it is plug and play, or you could just get the QR.
I called the sending unit being shot when we pulled over...
Old Mar 8, 2010 | 07:40 AM
  #1589
Correct. With the clearances all off and what appears to be a lack of piston skirt, I would abandon that altogether. The further you stray from a 2.0L, the faster it will fall apart.
Old Mar 8, 2010 | 09:04 AM
  #1590
Jk's03EVO's Avatar
Well oil pressure is reading fine now. That's the funny thing. Also, now a starter relay is killing me. When I got back home Saturday I pulled the car in the garage and troubleshot the TPS code. Well I guess the whole 20-30 minutes drained the battery enough. Well the battery is reading normal and when I hook up cables and get a jump voltage goes to 13.9 and it pops alive. Now that I went to get the alternator, battery and starter checked at Advanced the starter is reading low. Funny thing is I was trying to figure out what this noise was in the engine bay that night and it clicked, litterally, about the solenoid. And after one of the guys there confered I am going to the 03 before I go to work and take those off for that just incase thing.
