Jax FL Social Thread
Old Sep 17, 2010 | 06:08 PM
  #2221
still*boostn's Avatar
Originally Posted by EvoVIIIFL
You'll be begging for me to use the low side boost controller...
BBBWWWWAHHAHAHAH, Im not talkn ****, but hey, your set up is alot better then mine, from built head(i do have dual springs btw, so i dont think any valves will be dancing), to your mani and turbo is 6mm bigger on the comp. side, along with intake mani, and bigger a/r.
But im a good driver, and i want to run you on 40psi, c16. please,.... do the same. dropping the engine in monday(if mike@awd has my tranny here then) so as soon as i hit around 1500-2000, havent decided yet. im getting josh to tune it.
so a friendly CALL OUT to you mr. jon(no cockness intended, i know your car is a beast.), but Sir-Spools-ALOT, should be pretty stout too.
Old Sep 17, 2010 | 06:31 PM
  #2222
tigeron's Avatar
Chill
FYI--You two better chill or an admin will jump in here, bout street racing on here....
Old Sep 17, 2010 | 06:41 PM
  #2223
Mother,
I told you not to call me out in front of my friends. Theres nothing about street raceing, which is illegal and dangerous, being said about doing this race on a street. I dont know who would actaully do something like that. We are doing it on a race track, a big one. I love you mom.
Will
FYI---I love you, and your ***** weak.
Old Sep 18, 2010 | 08:38 AM
  #2224
04EBevo's Avatar
Rons "stuff" is far from weak! I can vouch for that! It is a stock block pump gas wonder!
Old Sep 18, 2010 | 11:05 AM
  #2225
I know. Just kidding/being a smart ***.
Big thnx to Aron for hookn it up with another radiator!(last one took sharpnal from the exploding engine.)
Old Sep 18, 2010 | 03:56 PM
  #2226
Fast_Freddie's Avatar
Veteran: Navy
Just got done installing some FIC high Z 1100cc and an AEM Uego for Justin, then took it out for a nice tune on 93... TPS Mapswitching enabled so he can fill up on moonshine on the way home!
FYI, do a boost leak every now and then guys, Justin had 2 bad boost leaks! One of course from the EGR hose...
Car runs tons smoother now and on Virtual Dyno put down 330hp & 300tq. Not bad for stock O2 housing and stock cams!
Old Sep 18, 2010 | 05:19 PM
  #2227
+1 on that, i got a sweet lil boost leak test set up if anyone wants to borrow it just shoot me a PM.
Old Sep 18, 2010 | 07:38 PM
  #2228
STWHY?'s Avatar
Thanks again Freddie..you are the man....moonshine..here i come.....Justin
Old Sep 20, 2010 | 05:59 AM
  #2229
EvoVIIIFL's Avatar
Originally Posted by 04EBevo
Rons "stuff" is far from weak! I can vouch for that! It is a stock block pump/METH gas wonder!
Fixed
Ron I'll race you at Gville for your bumper!
Old Sep 21, 2010 | 02:30 PM
  #2230
Capone X's Avatar
my clutch master cylinder blew up today, im going to install the magnus one but i dont have a grinder to remove the screws.
Does anyone have a grinder, burr grinder that i can borrow?
Old Sep 21, 2010 | 02:55 PM
  #2231
I got a bench grinder, but dunno if thatll help seeing that its bolded down to a work bench.
Does anyone have an extra -3 AN fitting with built in restricter for a gt35 turbo?
Old Sep 21, 2010 | 04:01 PM
  #2232
Veteran: Navy
Try Wells Performance in Arlington... my buddy got one a few weeks ago there... You can also try Wheeler Power products on the westside (103rd), they had a ton of AN stuff and I am sure Stage6 has one as well
Old Sep 21, 2010 | 04:04 PM
  #2233
Capone X's Avatar
Negative on the bench grinder i have to manuver it underneath the clutch pedal on the firewall..
I have a dremel, i wonder if i can find a burr grinder bit for that.
Old Sep 21, 2010 | 05:57 PM
  #2234
awesome, the one from wells, did it have the restrictor built in?
Old Sep 22, 2010 | 02:09 AM
  #2235
evoluXrichie's Avatar
Help on the northside
I've got a bolt hole stripped out from my valve cover to my head... Any suggestions for a place to take my car to get it filled in and fixed?
