am a noob and needs help
Old Aug 21, 2010 | 01:15 PM
dee242's Avatar
Question am a noob and needs help
Ok so am geting me a evo 9and am gonna get a HKS air intake ,Carbon ti exaust ,Bov,and a Boost controler. i know i am gonna have to tune it but i dont know how 2 tune it where 2 tune it i live in Orlando Florida i am not rebuilding the engine and whats the max psi of boost i can run after i tune it with those moods on it and i also dont know where to get the mods installed. hey i also dont know witch boost controller to get but i want a manual one where should i get the boost controller from
Old Aug 21, 2010 | 01:24 PM
Psquared's Avatar
First, spend some time searching around. You will find every one of these answers on here hundreds of times. Second, why are you getting a bov? Is the one installed on the car now not functioning properly? Is it leaking? If it's the 9 metal bov, chances are with your current mod list you won't be needing a bov for a while. Spend the money on a walbro fuel pump instead.
--If i'm not mistaken, TTP (track & tarmac performance) is in orlando. They specialize in building the 4g63. Hit them up for all your local needs. http://ttp-engineering.com/catalog/e...f8cb1873681fc3
As for manual boost controller, I would suggest the Hallman Pro.
Old Aug 22, 2010 | 05:42 PM
Wiznaz's Avatar
Get the car first and make sure everything checks out fine before you try to modify anything. Burying the car with mods when it's not running right to begin with can only make a problem harder to solve. Like Psquared said, ditch the BOV idea until you absolutely need it. I'd recommend 24psi for a nice average tune on the stock turbo but you can run boost closer to 30psi with a dialed-in agressive map. For a MBC, look into Hallman, they make a nice boost controller. I'd recommend looking at Import Image for getting your parts. They're in Florida too.
akinnear03
Jun 24, 2010 11:22 AM
Makos1610
19
Apr 21, 2006 09:03 PM
Go_Lancer_Go
Lancer Aftermarket Forced Induction Tech
13
Oct 16, 2005 10:14 PM
