Weld in roll cage
Old May 6, 2011 | 06:15 AM
mouseIX's Avatar
Originally Posted by scorke
Mouse FWIW I wouldn't take your car to Forged for a boost gauge install much less a weld in cage ( possibly live saving mod) job.
If you have any questions about Piper or Forged feel free to PM me for more info.
Sam
I totally agree, I made the mistake of going to Forged when I first moved back to ATL, I was naive.
Old May 6, 2011 | 10:11 AM
EAVWIDL's Avatar
Should have some pics here before end of the weekend of the Auto Power cage. Mine also came with with adjustable seat back braces and extra door bars that can be welded into place by the installer.
Old May 6, 2011 | 12:08 PM
mouseIX's Avatar
Sounds good, I'm looking forward to it.
Craig
Old May 6, 2011 | 02:56 PM
Balrok's Avatar
I'm not a huge fan of gusseting the Pillars when you don't need to. If you bend the bar right you don't need to add the extra weight. Most shops loose tons of time and $ on cages because they don't do it often, so they get lazy and cut corners instead of getting the angles right for every car, because every car is unique. Not to say that their not any safer, just that their generic and don't fit as well as they should.
Some examples of taking the time to do it right:
Mine - since it's an ST/TT car he stitch welded everywhere. The bar you see in the A pillar? 6 inch welds with about 2 inches between them. On the open spaces you can bairly fit a piece of paper through there. Which means that in an impact, the cage and not the gusset takes the impact first.
Old May 7, 2011 | 04:43 AM
scorke's Avatar
Balrok , have you held a gusset like that in your hand? I would be surprised if the whole set added more than 4-5 lbs per total. Any sort of gusseting between the chassis and cage is a big help to reducing the amount that the cage twists independently of the top of the car. The more places you tie the cage into the chassis the more strength you get. Unless you are restricted by your sanctioning body to a given number of attachment points, if your budget permits the more the merrier when it comes to safety. Also your quote amongst the pictures, I believe you are referring to the B-pillar not the a-pillar. With regards to the cage taking the impact instead of the gusset, I can think of lots of reasons why you would want something other than the cage taking the impact in a big hit...
I do however totally agree that the bolt in style cages leave a lot of room for improvement when it comes to fitment and positioning in the chassis, but they also cost a LOT less, so it's a compromise.
Sam
Old May 7, 2011 | 05:11 AM
mouseIX's Avatar
Sam
I don't want to compromise when it comes to my safety.
Excellent discussion btw, this is the kind of information I was looking for. Thanks for the helpful input!
-Craig
Old May 10, 2011 | 02:52 PM
EAVWIDL's Avatar
This is the 6 point cage I ordered from Auto Power. The fitment was perfect and required no grinding, cutting or beating. The cage is very solid. Don't know if this helps with your decision or not.
Old May 10, 2011 | 03:53 PM
mouseIX's Avatar
Thanks for the pictures. How is the clearance with your left leg while driving?
Craig
Old May 10, 2011 | 07:47 PM
sacul33's Avatar
You can also check out Robinson Racing up in Cumming. They will build any cage to meet any specs.
They have built a lot of cages for many race teams.
Lucas
Old May 10, 2011 | 07:53 PM
Aliengotpsi's Avatar
Tthat bolt in cage cannot be good for drag racing ?
Old May 11, 2011 | 10:43 AM
mouseIX's Avatar
Lucas
Thanks!! That is not far from where I live. I will look them up and call this afternoon.
Craig (Kuruma on EvoA)
Old May 11, 2011 | 10:58 AM
06MREvo's Avatar
Piper Motorsports Manassas VA hand's down.
Ask for Robbie or Mich.
Sam
Awesome...that is a pretty serious cage right there...
Old May 11, 2011 | 12:52 PM
EAVWIDL's Avatar
Craig
No problem, Obviously its a little tighter but still just fine for driving.
Old May 11, 2011 | 12:55 PM
EAVWIDL's Avatar
While it might not be specifically approved by NHRA it will be more than sufficient for the weekend drag racer.
Old Jan 9, 2012 | 11:55 AM
Pirana's Avatar
^not if you in the 10's
smoothevo
May 4, 2017 03:49 PM
nismo3183
Northeast Region
Dec 12, 2016 07:14 PM
Aaron20
Northwest Region
25
Oct 6, 2010 08:41 PM
nick735
Oct 20, 2007 01:44 PM
JDM-Spec.com
Apr 21, 2005 10:29 AM
