Stock battery problem HID Lights
Hey Im ridin 09 GTS running serious sound system and HID 8000K lights. Lately i'm having problems with my headlights either blinking or one side not turning on. I'm looking for a good deal on a yellow top battery so it will fix this let me kno
thanx
thanx
I hear the Yellow is not that great, Kinetik power cells are better. http://www.kinetikaudio.com/2009/default.asp
you need both a relay and anti flickers to fix your hid issue.
second their are volt meters that can monitor your voltage. check to see how low your kips are.
Anti flickers will help since they are mini capacitors, so even in voltage drops they can still prevent the bulbs from going out. they should flickers if they are rigged to the battery via a relay. of course I am no electrical wiz. but thats based on what i know so far.
