TPMS Question
Old Oct 11, 2011 | 10:56 AM
Crester's Avatar
I think your Uncle may have meant something else when he said he used spacers to make the rims fit. It's not so common for people to use devices to change the bolt pattern of the rims. People usually use spacers to help push the rims outwards to help clear suspension components, etc.
Old Oct 11, 2011 | 11:04 AM
Crester's Avatar
Originally Posted by evo_soul
correct. I think... I was speaking more from my beef with its implementation in the Lancer. Its a locked system that has only 4 banks. I think if it had 8 banks for two sets of sensors I would love the system. In personal situation... I was down to about 25psi and no trip of the sensor. no idea what happened, but hey... no big deal.
I will say you are correct. They are to inform those of the pressure levels in their tires. And in the end its good for the environment. My beef would be that its a government standard technology on all cars made today. But if they had sensors that would tell you actual PSI pressure vs. a trip alarm... I would fall in love with it. I hope someone invents this and puts it standard in their vehicles. For mitsubishi it would be a great GREEN PROGRAM I know EVO guys would like that
I think the fact that we can only store one set of sensors at a time is absolutely nuts! Especially considering that this is Canada... and pretty much everybody is going to have two sets of wheels.
The dealerships must love it tho... they get to charge 1-2 hours of labour each year every time some changes their tires.
Why isn't there an affordable machine that can do this???
Old Oct 11, 2011 | 11:12 AM
LIVEEVIL's Avatar
Im so depressed over these rims now.....(though I am holding out hope) Maybe Ill ask my mechanic if he knows how to change them from one size to another. BLEH
Old Oct 11, 2011 | 11:14 AM
LIVEEVIL's Avatar
As far as the darn TPMS are concerned, I'm holding out hope my mechanic may have a tool to do this. I don't have much hopes but who knows..
Old Oct 11, 2011 | 12:59 PM
Sandro's Avatar
TPMS pairing
Originally Posted by Oksamit
...As far as 2010 models, Lancers' computer can only have 4 sensors "recorded"/paired to...
What about the 2011 models?
Thanks
Old Oct 12, 2011 | 06:49 AM
08Lanc3rGTS's Avatar
don't quote me but i believe costco reset tpms sensors free of charge if you buy your tires from them
Old Oct 12, 2011 | 10:08 AM
Oksamit's Avatar
Originally Posted by laksman91
I just woke up so... I'll give a proper response later.. but the bolded is incorrect information.
edit:
the bolt pattern is the distance between these two points:
The hub bore is something else and can vary depending on car. Mitsubishi example 67.1
you can have some sort of wheel spacer style thing that will convert your pattern.. but i wouldn't bother .. 5x114.3 has the best rims out there!
I should have been more clearer with what I wrote. The bolt pattern is the diameter of the bolt/hole centers. Per attached.
I have asked guys at Maple about it for the 2010, which I drive. It never hurts to ask in your case with a 2011. May be Mitsubishi has started thinking about more practical things for their customers. -
File Type: pdf
Old Oct 12, 2011 | 10:14 AM
Enjoi's Avatar
You all know that there are direct differences between Low Tire Pressure and TPMS... They are not the same thing...
Old Oct 12, 2011 | 04:18 PM
LIVEEVIL's Avatar
based on that attachment........it makes me think boring the rim is all the more possible......, either that or maybe its possible to turn the rim into a 112 and a 114.3 by drilling an extra set of holes....hmm.
Old Oct 12, 2011 | 04:56 PM
Crester's Avatar
Don't kill yourself modifying a set of cheap rims to fit your car...
Old Oct 12, 2011 | 05:22 PM
KahoX's Avatar
just find a hub and bearing in 5x114.3 that will fit your knuckle...
edit: make sure the drive shaft fits the new hub
Old Oct 12, 2011 | 07:51 PM
LIVEEVIL's Avatar
There not exactly cheap. Im just getting them for cheap..(pretty much free). I think my uncle paid close to 2600 for them.
But anyways......until I actually get the rims, Ill have to see for myself what the "deal" is. I think I'll ask my mechanic if he knows of any ways to do it, like ill borrow one of the rims and get my mechanic to check it and all to see what we can do.
Welcome2GoodBur
May 6, 2016 12:44 PM
heavyD
14
Oct 6, 2009 10:45 AM
akj237
Aug 6, 2009 02:44 AM
Neal@tirerack
Feb 9, 2008 07:15 AM
sunstealth
Sep 28, 2007 06:28 AM
