20g at the dragstrip (videos)
Old Mar 4, 2006 | 08:31 AM
Cloud's Avatar
Did you drop launch it or modulate the clutch?
Old Mar 4, 2006 | 08:32 AM
justchil's Avatar
Takes a few times to learn how to get a good launch.. just sucks you broke something I always worry about this when at the track.
Old Mar 4, 2006 | 08:42 AM
4TUN8's Avatar
I tried to slip it a little bit, but I was using a technique that WarrTalon uses. He starts letting the clutch until the car starts to roll, then he does a quick slip and hammers the gas.
It was working, working so well that the car wheel hopped and broke 1st.
I think Clayton owes me a gear for listening to him!
We ran a couple more times after that, but either I just suck that much launching or the gear being broke was making the car impossible to launch.
I'm HOPING to pull the trans on wednesday.
Old Mar 4, 2006 | 08:45 AM
woodside's Avatar
its always a bit odd launching on a new power but u should get it down with some seat time.
Old Mar 4, 2006 | 08:53 AM
platinumspecv's Avatar
Ahh... so a new tranny huh? Get a built one now... and some motor mounts
Old Mar 4, 2006 | 08:59 AM
DCSilvrEvo's Avatar
That would work!
Old Mar 4, 2006 | 09:04 AM
4TUN8's Avatar
We'll probably rebuild the stock trans...from what I'm told, the wheel hop will kill a built tranny just as quick.
I think we'll go with lower tire pressure, maybe some motor mounts.
Old Mar 4, 2006 | 09:22 AM
fimotorsports's Avatar
what kind of tires do you run
Old Mar 4, 2006 | 09:56 AM
4TUN8's Avatar
Avon tech m500 245/45/17
Old Mar 4, 2006 | 03:33 PM
Ivan_C's Avatar
Ben. are you sure you broke the trans and not the front diff? I find it really had to believe that style of launching would break 1st, when the way I launch and 1st is still in one piece. Good mph but it's to be expected from the power you have. Can you post up your first pass, I want look over it. Text format is fine.
Ivan
Old Mar 4, 2006 | 04:01 PM
4TUN8's Avatar
R/t.................. .824
60'................ 2.101
330...............5.483
1/8................8.199
Mph..............89.97
1000.............10.508
1/4................12.411
Mph...............119.30
Old Mar 4, 2006 | 04:12 PM
woodside's Avatar
its more the wheel hop then anything that broke whatever broke...no matter how u launch wheel hop can happen. it just sucks
Old Mar 4, 2006 | 04:15 PM
justchil's Avatar
Interesting... I'll have mine at the 1/8th mile on the 16th or 18th but last year I was trapping 89mph with the stock turbo on pump gas. Definately an 11sec car with a good launch and quick shifts.
Just out of curiosity what flywheel did you go with? I wonder if some stickier tires would help cut down on wheel hop some.. you definately want to spin but too much is bad :\
Old Mar 4, 2006 | 04:20 PM
4TUN8's Avatar
spinning and wheel hop are completely different.
Old Mar 4, 2006 | 04:23 PM
braceyaself's Avatar
howd u break 1st ? would be the hardest gear to break? lol did it wheel hop because u got off the thorttle or because of higher hp and cold weather?
