Shortblock specials from Jackson Auto Machine
Old Oct 1, 2008 | 05:30 AM
Jackson Machine's Avatar
For the month of October we are running a special on our Stage 3 stroker and 2.0 shortblocks. This applies to EvoM members only who place their order between Oct.1 and Oct.31. When you order you MUST mention that you're a member to qualify. Special price does not apply to custom orders and is valid while supplies last.
For detailed information on what goes into our shortblocks, view this thread;
https://www.evolutionm.net/forums/sh...d.php?t=334949
For information on our JAM Spec Venolia pistons, view this thread;
https://www.evolutionm.net/forums/sh...d.php?t=367991
Stage 3 2.0L;
Your block is hot tanked, fully cleaned and inspected then the cylinder walls are sonic tested for thickness. Then it is precision square decked, bored and 4-step torque plate honed. The block is de-burred and the oil galleys are modified. Once the machine work is complete the block is final washed and all clearances are measured and recorded and your rings are fit to the cylinders. The rotating assembly is then balanced and all parts are final washed. Balance shaft elimination kit is installed along with the oilers, new freeze plugs and galley plug. The shortblock is then assembled, painted and ready for delivery.
Parts included;
Brand new JAM crankshaft
ARP Main Studs
Oliver billet rods
Coated ACL Rod, Main and Thrust bearings
JAM Ultra file fit ring set
JAM Balance Shaft Elimination Kit
New freeze plugs and galley plug
Special price is $3565
Stage 3 2.3L;
Your block is hot tanked, fully cleaned and inspected then the cylinder walls are sonic tested for thickness. Then it is precision square decked, bored and 4 step torque plate honed. The block is de-burred and the oil galleys are modified. Once the machine work is complete the block is final washed and all clearances are measured and recorded and your rings are file-fit to the cylinders. The rotating assembly is then balanced and all parts are final washed. Coated balance shaft bearings are installed along with the oilers, new freeze plugs and galley plug. The shortblock is then assembled, painted and ready for delivery.
Parts included;
Brand new JAM 2.3 Stroker crankshaft
ARP Main Studs
Oliver billet rods
Special price is $3575
Please visit our website, www.jacksonautomachine.com
To view our shortblocks and components, https://www.jacksonautomachine.com/h...m?sectionId=31
Old Oct 1, 2008 | 06:48 AM
stryfetew's Avatar
Price with or without core?
Old Oct 1, 2008 | 07:12 AM
Ev0cRaZy's Avatar
At the top it says, YOUR BLOCK....Core.
Old Oct 1, 2008 | 03:59 PM
That's the price if we use your core block. There is also the option of using a new block which we can supply. If you purchase the block the same time we do the build we will take $200 off the cost of the new block as well which would make it $1600.
Old Oct 1, 2008 | 09:17 PM
nitz's Avatar
jam stroker without balance shafts?
Originally Posted by Jackson Machine
Stage 3 2.3L;
thought your strokers retain the balance shafts. is this a new change or a typo?
Old Oct 2, 2008 | 05:48 AM
Old Oct 2, 2008 | 05:49 AM
typo Thanks for pointing that out. We retain the shafts in the strokers
Old Oct 2, 2008 | 05:55 AM
Forevapmp's Avatar
I'm very interested....... but I might have to order close to Oct. 30th. FTL!!!
Old Oct 7, 2008 | 11:21 AM
h22gordo's Avatar
So only the 2.3 strokers retain the balance shafts?
So on the 2.0, the balance shafts are removed?
So how much HP can this block handle?
Old Oct 14, 2008 | 12:27 PM
h22gordo's Avatar
^bump?
Jackson Machine
117
Jun 4, 2015 03:45 PM
KennyRS
76
Oct 10, 2012 07:58 AM
lonestarevo83
Aug 17, 2011 04:35 PM
gl4662
For Sale - Cars For Sale
27
Feb 29, 2008 04:27 PM
Jackson Machine
18
Sep 14, 2006 09:57 AM
