Only for engine bluiders or dyi installers
Old Aug 1, 2011 | 05:11 PM
apagan01's Avatar
FYI engine builders or dyi installers;
Old Aug 1, 2011 | 05:13 PM
apagan01's Avatar
edit
Old Aug 1, 2011 | 05:14 PM
murlo26's Avatar
I'll be running that break in oil in the next few weeks
I think ERL coats all the rotating assembly in the lube as well...good stuff.
Old Aug 1, 2011 | 05:15 PM
SOEuro's Avatar
What's different about this break in oil than any other conventional oil?
Old Aug 1, 2011 | 05:17 PM
Kracka's Avatar
PlanoEvo ran that break-in oil in his MAP Stage 2 2.3L for the first ~500 miles I think.
Old Aug 1, 2011 | 05:22 PM
apagan01's Avatar
Good to hear
Old Aug 1, 2011 | 05:29 PM
apagan01's Avatar
not trying to blow you off, but if you want dig into this link and it will help you.
http://www.amsoil.com/storefront/images/BRK_300.jpg
Hint hint, friction modyfier's must not be containned in an oil for propper break in, and oils not specified for breaking in an engine do contain friction modifiers, some more some less.
So what friction modifiers are, they help reduce friction between moving parts, in this case we care about the ring sealing against the cylinders. During the break in period of an engine we want some friction to help "polish that metal" so rings and cylinders seal.
This is one of the big issues why some cars still smoke after engine was built, among other issues like loose tolerances.
Old Aug 1, 2011 | 06:49 PM
Piro Fyre's Avatar
What are the part numbers for both of those? Something tells me my local Amsoil dealer hasn't heard of these yet. I order things he never even heard of...
Old Aug 1, 2011 | 08:12 PM
aka.ralliart15's Avatar
Great to see Amsoil coming out with new stuff!!!
Old Aug 2, 2011 | 07:07 AM
apagan01's Avatar
i have plenty of these, too many
Old Aug 2, 2011 | 07:10 AM
apagan01's Avatar
I know it about time we had some stuff like this
