Fathouse Fab ***New Release*** Bolt In Fuel Cell
I would really like to know where you came up with the 35 pound weight savings?
Stock tank is 27 pounds without sending unit which has to go in new one. Gas tank heat shields weighs 5 pounds total. 32 pounds total for a stock empty tank.
I would like to know exactly how much your tank weighs without a sending unit?
I'll be buying one sometime early next year. Looks great and I can't wait to get this on my car!
The 35lbs was based off a before and after weight of a customers car. We have not had a chance to weigh out each individual component.
We are doing another run right now. Once we have them completed I will post up the weight of the cell itself.
As long as its no taller then the factory pump setup then yes it would fit. You could still run all factory lines if you use a factory fuel pump hanger. You would just transfer your entire fuel pump housing assembly over to this fuel cell.
Demetri we could not get 10 gallons out of it. We may be able to fit one more gallon in the same space but definitely not a 10 gallon cell.
I would only assume the buschur Dp is the same height as the factory. What are people running with this tank?
i am pretty interested in this but i am still being a little ***** on the fuel capacity. slowly i am leaning towards it.
Here are a few shots of the last run in production and being shipped.
I have one person interested in one right now, if I can get two more I will do another run.
Factory Fuel Pump Housing Rings being machined in our lathe
Piano hinge baffle systems welded in, bottom half ready to be joined to the top half.
Finished and cleaned up - ready for packaging.
MADE IN MURRICA!
MADE IN MURRICA!
Another batch of fuel cells shipped out this week. I have already started on another run, if you want to reserve one send an email to sales@fathousefab.com
