MAPerformance Mitsubishi Lancer Evolution 8/9 Dry Sump Kit is now available for pre-order!
Pricing for pre-orders will be $3999.99!
Notes:
- Must be used with an ATI damper
- Includes lines from pan to pump, you're responsible for mounting tank/oil filter housing and sourcing/routing lines
- Does work with OEM timing covers
- You have the option to have your existing oil pump modified or purchase a new one
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||
: MDunn@MAPerformance.com|||||
: 651-348-8811 x 107|||||
how are there driven? looks to bee off the timing belt... also what needs to happen to the oem oil pump just shave the teeth of the gears? could you post a link to the ati damper you mention is required? what size are the -AN fittings that are used with the kit?
one more... how much wood could a woodchuck chuck... if a woodchuck could chuck wood...
It is driven from the crankshaft, thus the need for the ATI damper. We will either modify your existing oil pump or modify a new OEM oil pump as part of the purchase. The hose and fittings are 12an, here is the ATI damper
http://www.maperformance.com/ati-sup...ic-damper.html
Also, he/she would chuck all the wood that a woodchuck could. I'd say somewhere around 42?
We have been making a lot of nice passes this season with this kit installed on our drag Evo!
Woodchuck would chuck a big WOODY
- New MAPerformance Dry Sump System for Evo 8 & 9 / Just $3999.99 shipped!
- MAPerformance Evo X Surge Tank Kit | Radium Engineering & Walbro 400lph!
- New MAPerformance 65mm Ported Throttle Body Upgrade For The Evo 8/9 for only $229.99!
- MAPerformance Evo X 3" Single Exit Catback Exhuast System Now Available
- MAP Evo X and Ralliart Inline Fuel Filter!
