Evo 10 Billet Chain Tensioner by MAPerformance!
Old Oct 15, 2014 | 12:55 PM
maperformance's Avatar
Introducing the latest addition to the MAPerformance 4B11T Engine Parts catalog: the Billet Timing Chain Guide!
Click the Link Below to View the 360 Degree Preview!
Click here to view the Billet Timing Chain Guide!
Made from the best Billet 6061-T6 aluminum, the Evolution X chain guide has been machined to meet the factory guide specifications with tighter tolerances to reduce chain wobble at high RPM's. It also implements the factory wear strip and is a direct bolt-on for the 2008-2014 Evolution 10. This timing chain tensioner is the last piece of the puzzle you need for a higher revving Evo 10.
The Evo 10 4B11T timing chain tensioners are cast from hardened plastic from the factory. While acceptable on stock engines, this plastic has been known to warp after seeing repeated high engine RPM's, which lowers their life considerably. This also allows for slight deflection of the chain, causing minor timing inaccuracies. By installing a billet timing chain tensioner from MAPerformance, you're ensuring your motor will be able to rev higher for longer.
Includes:
  • CNC Machined 6061-T6 Aluminum Chain Guide
  • Replacement Wear Strip
  • All required hardware for installation
Berndog67
Aug 3, 2017 04:25 PM
maperformance
Oct 15, 2014 12:49 PM
APM Racing
Midwest Region
Jan 31, 2014 03:13 PM
Gruppe-S
Mar 6, 2012 01:24 PM
evokid4life
Jul 16, 2010 08:33 AM
