Install price for Stage 1+
Old Oct 9, 2004 | 03:08 PM
RenoEvo's Avatar
How much would it cost to get this set up installed. Does vishnu install their packages or am I gonna have to take it to GB or gruppe-s?
Old Oct 9, 2004 | 03:10 PM
David@Vishnu's Avatar
We have a full install center stock to stage 1+ is $500
Old Oct 9, 2004 | 04:06 PM
EVOtook's Avatar
How about just cams and cam gears?
RenoEvo's Avatar
how much extra would it be for headstuds, bolts, and a new head gasket?
Old Oct 9, 2004 | 04:14 PM
$350
Old Oct 9, 2004 | 04:15 PM
Bolts? con rod? if so 700 or so
Old Oct 11, 2004 | 02:49 PM
Evil EV0's Avatar
Lol, ssorry just thought Id ask, how much to just install cams? Once I get some cams installed I'd like to get it on the dyno.
Old Oct 11, 2004 | 03:08 PM
SuperHatch's Avatar
Correct me if I'm wrong here David but....
Head studs alone won't add much if you're doing cams since you don't have to pull the head to do them.
I'm not sure why you'd want to replace the head gasket unless you want to lower your CR with a thicker gasket or your stock one is leaking.
As far as ConRod bolts, those cost more since the rod ends need to be re machined when the bolts are put in, this is labor intensive and costs some bucks to do labor-wise.
So if he wanted headstuds with the 1+ install it wouldn't add much. It's if he wanted the HG and ConRob bolts that the cost increases dramatically.
- Steve
