boost on stg 1 map(93 octane)
Old Nov 17, 2004 | 07:06 PM
gsujeff55's Avatar
how much boost are you guys seeing on this map? or how much am i supposed to be seing? im getting ~24 tapering down to ~21....is that normal???
Old Nov 17, 2004 | 08:04 PM
wthoevo8's Avatar
When I've the stage 1+ setup on 93 octane, it spike up to 24, 25 psi. Shiv tune it back down to 22, 23 peak then taper to 19 psi.
Old Nov 17, 2004 | 08:06 PM
shiv@vishnu's Avatar
Yep.. dial it back to 22psi peak and it will taper naturally down to 18-19psi by redline.
Shiv
Old Nov 17, 2004 | 08:40 PM
gsujeff55's Avatar
how would you best suggest to change the table to dial it down?
thanks.
Old Nov 17, 2004 | 09:00 PM
With your mouse, select the entire boost map (it's labelled either as "unknown" or "boost"). Right click mouse and select "Add Offset". Type -5 and hit enter. This will reduce all values by 5% which will bring boost down a bit. Add or Subtract and offset until you get the peak boost level you desire.
Shiv
Old Nov 17, 2004 | 09:03 PM
gsujeff55's Avatar
awesome, thanks brotha.
