Need to confirm cam gear settings....
Subscribe
Dec 6, 2004 | 05:34 PM
I currently have a Vishnu Stage Zero. I just locally purchased a 3" DP and RT hi-flow cat as well as some Fidanza adjustable cam gears. My question is this:
What settings should I use on the cam gears so that I can use the Stage One maps on my XEDE?
I realize that the Vishnu cam gears come preset when you purchase the stage one upgrade, but I need to know where to set the Fidanzas to match the Vishnu settings. Anyone with any knowledge about this, please pass it on, it would be greatly appreciated.
thanks in advance,
Tony
Dec 6, 2004 | 07:02 PM
if they are the regular fidanza gears there should be 2 guide holes make sure you put the evo peg on the cam and set them -5/-5 if there aren't 2 holes the gears are most likely dsm gears and need to be installed with 7/7 at tdc...see this thread for lots of confusion. https://www.evolutionm.net/forums/sh...ad.php?t=65155
Dec 6, 2004 | 07:04 PM
the old vishnu gears are fidanza so i think they should be 12* to the left of tdc where ever you put that. that is if these are dsm gears. hope this helps some.
vin
Dec 6, 2004 | 08:24 PM
Thanks asasin,
They should be here by wednesday so I'll take a look to see which ones they are. In the meantime if anyone else has any info I would really appreciate it.
thanks again,
Tony
Subscribe
