XEDE harness???
Old Feb 13, 2005 | 11:01 AM
asasin79's Avatar
XEDE harness???
is there a wire on the xede harness i can tap for a tach signal? i know pin 58 on the smallest plug is tach signal, but the xede reads rpm when you hook a computer up. so which wire is it?
thanks
vincent
Old Feb 13, 2005 | 03:10 PM
asasin79's Avatar
uh...bump.
Old Feb 13, 2005 | 03:18 PM
hkfeet's Avatar
This thread might help ya out.
https://www.evolutionm.net/forums/sh...ad.php?t=98701
Old Feb 13, 2005 | 03:48 PM
asasin79's Avatar
thanks man...but i'm looking to get a tach signal by using a vampire clip on one of the xede harness wire so i don't have to use a vamp clip on the ecu wiring. i just need to know which wire in the xede harness reads rpm.
Old Feb 13, 2005 | 06:49 PM
asasin79's Avatar
uh...anyone else?
Old Feb 13, 2005 | 09:13 PM
mmoranda's Avatar
Use this to cross reference to the xede harness.
http://www.roadraceengineering.com/e...-ecuwiring.htm
Old Feb 13, 2005 | 09:20 PM
asasin79's Avatar
while i appreciate your response and desire to help, perhaps it was overlooked that i want to tap a wire for a tach signal other than the PIN 58. i know that the xede shows rpm when you plug it into a computer and it does NOT tap wire 58 so where does it pick up a tach signal?
thanks again
Old Feb 14, 2005 | 04:03 AM
Jorge T's Avatar
I think it is a generated signal from the CAS replicator, not sure if a signal can be obtained by wire tapping. I feel ya ,I hated tapping into wire to pin 58
Old Feb 14, 2005 | 08:04 AM
asasin79's Avatar
thanks Jorge, that is what i was "thinking", too. but i'd like to "know" so shiv, david, dustin or anyone who can give me a definate answer please do so at your convenience.
thanks
vincent
Old Feb 14, 2005 | 11:58 AM
Dustin@Vishnu's Avatar
I cant give a definate answer, but i would use pin 58. What do you want to hook up anyways?
Old Feb 14, 2005 | 12:04 PM
asasin79's Avatar
a monster tach from sport comp...lol. j/k i recently bought a zeitronix wideband and need a tach signal for dataloging. i would rather not put a permanent cut into the factory wiring harness. thanks for your help. i might just try the CAS and see what happens. worse case no signal?
Old Feb 14, 2005 | 07:37 PM
asasin79's Avatar
nobody knows?
Old Feb 15, 2005 | 01:59 PM
asasin79's Avatar
hey bump
EvOcHaRgeR
Jan 25, 2006 11:42 PM
Jon H
12
Dec 30, 2004 09:13 PM
