Vishnu HELP!!!...
Old Feb 13, 2005 | 01:01 PM
EVO MR's Avatar
Vishnu HELP!!!...
I have a 05 MR and I am getting my car ready for the dyno day you are holding in april in GA. All I have as of right now are Full turbo back exhaust with new 02 housing, walbro fuel pump, Hallman boost controller.
Well last night I installed the xede piggy back into my car with the 93octane 0+ map and my car feels very week!! it doesnt run as smoothly and hesitates sometimes. I installed everything exactly per your instructions on your web site.
Is there a problem with the map being on my 05 MR ecu? is there a different map with different fuel and ignition curves? what should I do, I will need to drive around 600 miles to GA to get tuned and I dont want to damage the engine at all.
Also what other mods should I do before The dyno day that I can drive 600 miles safely? (I would really like to do your cam gears, and HKS 272 cams but i'm affraid to drive them so far with out a tune
whats your advice?
Thanks, Chris
Old Feb 13, 2005 | 01:20 PM
Dustin@Vishnu's Avatar
Give this map a shot...
https://www.evolutionm.net/forums/at...chmentid=55893
Keep us updated.
Old Feb 13, 2005 | 01:21 PM
jfh's Avatar
jfh
Chris,
Where did you get the map from? Try one of the new MR 05 sub Zero maps that Shiv added in post # 15 on this thread .
Hope this helps.
Old Feb 13, 2005 | 01:22 PM
EVO MR's Avatar
cool ...thanks
I have to go get my friends laptop to download it to my xede
Old Feb 13, 2005 | 01:28 PM
EVO MR's Avatar
will this map work with my mods or is this the base map for the completley stock evo?
Old Feb 13, 2005 | 01:33 PM
jfh's Avatar
jfh
It's better than what you have and the only 05 map currently available for public consumption without custom tune. It may be conservative but will not harm your car
Old Feb 13, 2005 | 01:52 PM
LateSleeper's Avatar
You may want to get rid of that Halman boost controller and put the stock vacuum lines back in. Your Xede can manage the boost. Just put the stock lines back in minus the pill in the line to the stock solenoid.
Old Feb 13, 2005 | 02:10 PM
EVO MR's Avatar
BTW that little pill was 100% easier to remove when you have the whole hose outside of the car... I just took the hose and a socket and pretty much rolled it until the pill came out (took me 2 seconds)
I will probally switch back to the xede controlling my boost, cause I cant get the hallman to stay steady... it still spikes all the time
Old Feb 13, 2005 | 02:13 PM
Az3ar's Avatar
Chris ...
Get this map and everything will be fine. Your MR is just slow
j/k
Old Feb 13, 2005 | 02:19 PM
EVO MR's Avatar
hahaha...how fast is your car right now????
j/k
Old Feb 13, 2005 | 02:33 PM
Az3ar's Avatar
j/k
well My car is very slow right now infact you can beat it walking ... Wish me luck with the machine shop tomorrow
