Attn: Shiv, David and Gurus
Old Feb 17, 2005 | 06:04 PM
  #31
Smogrunner's Avatar
Originally Posted by evo81
we won't beat you up to bad .where ready for you vishnu guys.it's all in good fun.as you can see in my sig,i stallow3n IE evo
I know, I know. Some of the best entertainment of the week has been watching IE and your boys body slam each other in the Vegas forum. All in good fun though.
Old Feb 17, 2005 | 07:31 PM
  #32
Az3ar's Avatar
Originally Posted by Smogrunner
First, keep in mind that Azar spent 1/2 the money for his turbo upgrade setup than IE. But, with that said, you guys are comparing the wrong cars. Yes, I make about the same power as Azar and have a better "area under the curve." But here is IE's dyno sheet with the exact same SAE correction factor and smoothing:
Look at Azar vs. IE:
RPM...............IE whp/ftlbs ............Azar whp/ftlbs
4000...............175/230....................180/235
4500.............. 290/340....................300/350
5000.............. 380/400....................340/355
5500...............395/375....................320/300
6000...............425/375....................350/305
6500...............445/360....................350/280
What we can see is that IE's Stage 3 has massively more top end power and has pretty much the same spoolup as the 3071. In fact, IE's run wasn't commenced until 3200 rpms, giving it less time to spool for the earliest part of the run. Had that run been started at 2200 rpms like Azar's, I'd bet that IE would have had higher numbers at 4000 and 4500.
Smogi, I know you personally and I know that you are better than that. You are holding hands with Alex Alex (so cute). Few points I have for you.
1- How can you compare IE evo to mine?? How can you compare a car that has more than $8K worth of parts to a car with 3.5K in mods??
2- How can you compare no cams no engine mods to a car with mods and cams??
3- How can you compare a 91 map or even 98 map to C16???
4- How can you compare 3037 to 3071 which both have completely different approaches??
With that said I believe you understand what I am saying. I have never said or compared my EVO to IE because the compression is way off. There is nothing in common between the 2 cars.
After all I thought that you are the guy who compare apples to apples not ALEX to ALEXIA.
Have fun guys and enjoy your cars (to each his own)
Old Feb 17, 2005 | 08:15 PM
  #33
Smogrunner's Avatar
Originally Posted by Az3ar
1. How can you compare IE evo to mine?? How can you compare a car that has more than $8K worth of parts to a car with 3.5K in mods??
Azar, actually, I DID feel kind of bad for that post. But you threw your dyno chart out in open in such a way that almost challenged analysis. I was trying to compare spool vs. power capability.
1. I pointed out the cost difference in the first sentence.
2. The only difference in power producing engine mods are cams. That is significant, but not so much for quick spool up.
3. IE was using Union76 100octane from the pump on that dyno run. Octane is comparable.
4. My point is that if you wanted that ATP kit, you should have gotten the 3076. Same spool, more power. At the time, there was no way to know that, so I don't fault you at all for getting the 3071. Your setup was a valuable source of information for many of us.
Alex, be nice.
Old Feb 17, 2005 | 08:23 PM
  #34
alex_alex's Avatar
I will be nice, on Smog's account
Az3ar, your evo and IE's evo have the EXACT SAME COMPRESSION. His boost levels may be a bit higher.
But i would have to agree with you, that there is nothing in common between the 2 cars. Nothing at all. . .
Old Feb 17, 2005 | 09:09 PM
  #35
gsujeff55's Avatar
so, for a $2500 ATP kit, you guys say no? even with the 3037 instead of the 3071....whats the consensus on that? i don't think ive seen a 3076 atp kit, can someone point me in that direction?
thanks
Old Feb 19, 2005 | 11:35 AM
  #36
Az3ar's Avatar
I just dont understand why i have that dip in power at 5.5K RPM? its not lean at this point and nothing seems wrong. Do you guys know whats going on?
Old Feb 19, 2005 | 11:49 AM
  #37
Smogrunner's Avatar
Even IE almost has a dip like that. My guess is that your MBC allows for a big boost spike when full boost is first achieved. I'm not sure but I'd guess that IE doesn't have as severe a spike because the Xede does a better job controlling that initial spike????
Old Feb 19, 2005 | 01:18 PM
  #38
jj_008's Avatar
I am betting a boost leak at high boost. Either your blow off valve is leaking or somewhere in your system there is a leak.
My theory is the high boost spike causes something to start leaking and once the boost settles down the leak is less or non-existent. That is probably why there is no dip on your low boost map. So check your clamps and your BOV.
Old Feb 19, 2005 | 07:43 PM
  #39
Az3ar's Avatar
I have no leak of any kind (at least now)That dyno was 4 months ago so I am not sure if I had any leaks back then. I hold like a rock 23 psi all the way to redline now (Like a ROCK). I don’t think it was a spike because a spike will be for a short time or small amount of RPM not as long as I have. I don’t know but I believe my tune is just off and I need to retune. Hope fully Shiv will solve my problems.
Old Feb 20, 2005 | 08:03 PM
  #40
Vishnu_Evo8's Avatar
the atp 3037 is pretty good.. but the problem lies in its massive lag when compared to the vishnu kit. this is partly because it uses the factory manifold. i have seen an atp kit making 360 whp on shiv's dyno on 100 octane before on stock intercooler... good power but laggy.
Old Feb 24, 2005 | 06:08 PM
  #41
93civEJ1's Avatar
you guys have me sooooooo confused...some of you guys say the ATP 3037 kit makes good power, just alittle more laggy, and then others say its junk...what is it and what would be prefered around the same price range? right now im still leaning on the ATP 3037S with .82 a/r.
Old Feb 24, 2005 | 06:29 PM
  #42
wthoevo8's Avatar
Atp 3037 with .82 a/r = lag, should try the .63 a/r...
Old Feb 24, 2005 | 06:37 PM
  #43
93civEJ1's Avatar
yes, but im more of a topend power kinda guy.
Old Feb 24, 2005 | 07:43 PM
  #44
value's Avatar
HKS 3037S = Power !!
Old Feb 24, 2005 | 07:47 PM
  #45
David@Vishnu's Avatar
Not AMS and stage 3 power
