Exede Map Question
Old Mar 14, 2005 | 10:46 PM
Kec's Avatar
Kec
Exede Map Question
Hey guys I am wondering can I run a Stage 1 Map with my mods cause I don't have the cam gears any advise will be appreciated thanks .
Old Mar 15, 2005 | 01:38 AM
dude's Avatar
I'd say you'd be fine with an off the shelf map until you can get some cam gears. You'll probably lose out on a couple horsepower but I don't think you'll hurt anything. If you want to be overly extra safe you could run a 0+ map but I'm pretty sure Shiv left enough of a margin in the Stage 1 map for you to be OK.
Old Mar 15, 2005 | 11:38 AM
Kec's Avatar
Kec
Ok than sounds good thanks .
Old Mar 15, 2005 | 11:53 AM
jman425's Avatar
It's XEDE !
Also, base maps are designed to run with stock air filters, so lose the k&n before you use the map.
Old Mar 15, 2005 | 11:54 AM
modvp's Avatar
In the thread link below, Shiv suggest that the stage 1 may be fine under certain conditions. https://www.evolutionm.net/forums/sh...highlight=xmap
Old Mar 15, 2005 | 01:45 PM
Kec's Avatar
Kec
Originally Posted by jman425
It's XEDE !
Also, base maps are designed to run with stock <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=24&k=air%20filters" onmouseover="window.status='air filters'; return true;" onmouseout="window.status=''; return true;">air filters</a>, so lose the k&n before you use the map.
Its a K&N Drop in Filter with the Stock Air Box
Old Mar 15, 2005 | 03:23 PM
EVOtagger's Avatar
shiv actually suggested that i use the stage 1 map even though i dont have cam gears...i followed his advice and my car runs great!
Old Mar 15, 2005 | 06:40 PM
Kec's Avatar
Kec
Thanks for the advice what are your mods and did you dyno the car yet
Old Mar 15, 2005 | 06:56 PM
EVOtagger's Avatar
engine mods at the time were 3" turboback, WORX dv, Upper IC pipe and FMIC
car ran great then...will be getting tuned april 2nd in Atlanta with cams and gears so i wont have any numbers for you with the stage 1 map
Old Mar 15, 2005 | 09:19 PM
Kec's Avatar
Kec
Thanks man keep me posted
