Aem Tru-Time cam gear (5 bolt) help !
Old Mar 22, 2005 | 07:58 AM
Evo23IG's Avatar
Its definately R (retard), I just had them installed but Vishnu told me to set them at -2,-2. I am running 264's cams.
Old Mar 22, 2005 | 08:13 AM
superman105's Avatar
EVO23IG
how do you like the idle and have you tried other settings before ?
like
-3/-3 or 0/0
Old Mar 22, 2005 | 08:23 AM
Evo23IG's Avatar
Well at first i had the car running at 0,0 which was alright you can feel it being a little bit lopey at idle, but when I switched to -2,-2 it felt better, I think it evens idle better now. You can still feel it being a little bit lopey at times but its almost just like stock. i been driving it for a week now and I don't even notice the difference in idle anymore. I am not going to switch the settings anymore, until if Shiv decides to switch them on the Dyno day in TurboTrix.
Old Mar 22, 2005 | 10:22 AM
silverEVO8's Avatar
So, if I move the dowel hole in the opposite direction of the arrow in the picture, I'm retarding the cam timing, correct?
Thanks
Old Mar 22, 2005 | 10:24 AM
93civEJ1's Avatar
ok...this is it....our motors turn in the clockwise rotation. In order to retard the cam timing the cam (center section of adjustable gear) would need to turn counterclockwise/left. The different brand of the gears and how they print the degree marks on the gears is what is confusing you guys.
Old Mar 22, 2005 | 10:35 AM
954DRGSR's Avatar
Originally Posted by Jorge T
Vishnu gears are - 0 + if you want to retard (-)the cam from 0, turn the cam gear nut to the left [you are actually moving the the cam] Are the AEM gears different?
Only difference between AEM & Vishnu gears is that the new AEM ones are Evo specific. I believe that the Vishnu gears are the DSM gears. I've had both - and both work fine.
Old Mar 22, 2005 | 11:24 AM
Dyno4mance's Avatar
You are correct the AEM gears have the calibration on the center piece and all the others are on the outside piece...this will confuse although the rule of thumb is the center needs to be rotated counter clockwise to retard cam timing
My 2c
Old Mar 22, 2005 | 11:29 AM
93civEJ1's Avatar
My 2c
bingo bingo bingo.
RedEV0
Past Winners / Entries
Feb 21, 2015 03:52 PM
EVO(boss)
Feb 16, 2015 02:34 PM
fyreant
14
Sep 12, 2014 02:49 PM
Yme
Jun 16, 2014 05:27 PM
dude
Jan 6, 2012 03:57 PM
