Aem Tru-Time cam gear (5 bolt) help !
Hey everyone.
I am going to rec. my xede tomorrow
as per Vishnu I'm suppose to set my 264/264 to -3/-3
I have AEM tru-time Cam gear, in which direction should I set it
{standing in front of the cam Gears there is
a letter "A" on the Left hand side and a letter "R" on the right hand side
should I set the timing mark 3 degrees to my Left hand side or 3 degress to my Right hand side !
it looks like this
AIIIIIIIIIII 0 IIIIIIIIIIIR
please help
tks
it looks like this
please help
tks
thank you for your comments
but, I saw post that the Vishnu is to the left
see attached
https://www.evolutionm.net/forums/at...chmentid=53339
see attached
yes u will turn the inside of the cam gears to the left thus making the outside center marking gotoward the R., even though the center cam section is going to the left, your timing belt and outside gears will be moving to the right.. I have the same gears.
Originally Posted by Jorge T
Vishnu gears are - 0 + if you want to retard (-)the cam from 0, turn the cam gear nut to the left [you are actually moving the the cam] Are the AEM gears different?
Originally Posted by 93civEJ1
this would be correct, but the markings are different on those. They put the degree markings on the inside, where AEM's markings are on the outside with the zero being in the center peice of the cam gear.
no, the dowel pin would move backward, making the teeth and timing belt move foward...I was thinking opposite of each other, the AEM timing markings are on the inside, and zero mark is on the outside....the vishnu ones are exact opposite. Please excuse my backwardsness up above.
I edited my above posts to be correct.
I'm actually thinking about modifying the stock cam gears to retard the cams the 4 degrees that seem to be the best for the stock cams...... Anyway, I want tp make damned sure which way to move the hole before starting with the mill
Originally Posted by superman105
thank you 93civEJ1
this is a bit confusing to me at first
but after you explain it I got it !
no problem man....hope i helped you out....oh and by the pic above with the drawing...if the center section moved in the direction of the arrow, that would be advancing.
