*Important* Things to know before you Dyno...
Old Apr 26, 2005 | 12:44 PM
shiv@vishnu's Avatar
1.a. Fuel. Make sure you fill up with the best fuel you can get, this will vary from state to state. Here in California we reccomend using 76. It has a higher octane than all others (some people even claim thier 91 is actually 92) and it doesn't have the MTBE additives like most other companies. we have seen the best results with it, heres some *proof*
https://www.evolutionm.net/forums/sh...d.php?t=126776
1.b. If you plan on doing a race gas map along with a 91 octane map, come with very little 91 octane in your tank. Bring with it a gallon or so of 91 incase you run out while tuning the 91 map.
2. Your car. Make sure all lines, fluids, filters, EVERYTHING, is in order. Trust me, you don't want to find out that your car has a boost leak that will take an hour or so to fix while it is on the dyno, and believe me... we see this happen all the time
3. Dyno Sheets. If you want your dyno sheets please bring a blank floppy disk so we can save your dyno runs to it. We no longer print out dyno sheets, we seem to go through printers every week
4. Your mods. Make sure you go over your mods with us over the phone before you go to get tuned. We might give you some suggestions, or ask you to bring stock parts if we feel that the setup might have some problems. This is only precautionary to make sure everything goes smoothly.
Call us if you have any questions
--Kim @ Vishnu
Old Apr 26, 2005 | 01:21 PM
kevin_stevens's Avatar
Can you save dyno sheets to USB keychain drives instead of floppy disks?
KeS
Old Apr 26, 2005 | 01:23 PM
KeS
Nope. Gotta love DOS
Old Apr 26, 2005 | 01:34 PM
EVOTEXAS's Avatar
I would not recommend that you get tuned on the "best possible gas" but rather the worst possible gas so that your tune will be safer when you only drive on the good stuff. Hopefully the tuner will be good enough not to blow your car up by recognizing detonation before it occurs.
Old Apr 26, 2005 | 01:41 PM
This "use the best gas" rule really only applies to CA cars where this is such a huge difference between junk gas (Costco, AM/PM, etc,.) to good gas (76). Of course, even our good gas is miserable compared to the 93oct you find in other states.
Shiv
Old Apr 26, 2005 | 01:53 PM
mrmefodman's Avatar
But if the difference is that much greater between the good and the bad in ca. then if tuned on the really good then when u have really bad the difference will be that much greater and more dangerous?
I always get 76 and dont put garbage in my car. but i am curious how big is the danger level of being tuned on good and then am stuk in the boonies and have to use Joe's gasoline.
Old Apr 26, 2005 | 01:57 PM
If you simply *have to* fill up on junk gas, all you need to do is go easy on the car until it burns off. By easy I mean no top speed runs or periods of sustained boost. It's not the end of the world if you do go on boost with bad gas as your knock sensor will intervene and pull back timing. Not a great thing but its there for a reason. It's just really unfortunate when someone comes to us for custom dyno tuning and they tell me that they last filled up at Rotten Robbie's and that they usually always use name brand fuels. Not only will the be down on power, I'll also end up tuning them on a gas that they will never use again.
Shiv
Old Apr 26, 2005 | 03:20 PM
Imyurturboluva's Avatar
SHIPDIT Dallas boy.
Old Apr 26, 2005 | 03:21 PM
mrmefodman's Avatar
Great ... now it all makes sence .
tnx
Old May 13, 2005 | 03:40 PM
Quickshifter's Avatar
Originally Posted by Imyurturboluva
SHIPDIT Dallas boy.
hahhahahahahahahhaahahhaa
Old May 13, 2005 | 03:57 PM
Az3ar's Avatar
--Kim @ Vishnu
5. Also, make sure you aren't on Shiv's "$HIT LIST" (friends with Mhyar or Chris)
J/K - I had to add it.
nj1266
Jan 25, 2026 01:43 AM
razorlab
Jul 31, 2008 11:45 AM
TURBODAWG
73
Feb 9, 2006 08:38 AM
G20
122
Jan 28, 2005 02:34 PM
