Need Advice: Stage 1 Xflash Installed P0304 SES
Old May 1, 2005 | 08:36 PM
revolagoy's Avatar
Well, I am very suprised that no one else on the forum has had the P0304 code. There must be something really wrong with my car.
Old May 2, 2005 | 06:42 AM
SuperHatch's Avatar
I had a P0303 code.... I couldn't track down the problem for a while, then it turned out my injector plug for the #3 injector was coming off. Mind you the car was 2 weeks old at this point and stock. I first checked plugs/coils as you did, then I started checking injectors and noticed that the connector was lose. When I pulled it off the plug itself was cracked. This was on a new stock Evo. I fixed the connector and put it back together, problem solved.
- Steve
Old May 2, 2005 | 10:42 AM
revolagoy's Avatar
Thanks SuperHatch! This is exactly what I was looking for. I'll check the injectors next.
Old May 2, 2005 | 12:25 PM
SuperHatch's Avatar
Hope that's your problem, but I don't think broken injector harness plugs are a common problem with these cars... good luck!
- Steve
Old Jul 4, 2005 | 01:16 AM
DaveLC2's Avatar
I just picked up my car a couple of weeks back and my buddy loaned me his tool and I too have a P0304 code. You can hear somewhat of a miss at idle but it runs fine. When I bought it they told me it was probably the gas cap not being fully tightend. Yeah...right. I love how a salesmanager becomes a tech when trying to close a deal. I am under warranty and will be taking it in shortly. What became of your P0304 code?
Dave
Old Jul 4, 2005 | 02:29 PM
revolagoy's Avatar
Well, it's a long story, but I'll try to tell you. I went to the dealer and they said that I was using race gas and that it may be clogging the injectors. They reset the ecu and give me a bottle of fuel injection cleaner. At first, I thought they were full of it, but the code didn't come back for a while. I was getting almost every time I started the car. I do use race gas at times for added safety in the 110 degree temps I drive in. Just two or three gallons of 100 per tank. The code eventually camevback after adding the fuel injection cleaner. So, I went back to the dealership and bought several bottles of the fuel injection cleaner. I ran two bottles in one tank with no race gas. I used a total of three bottles all together. The code didn't come back for several weeks. More cleaner and no more code. I am keeping my fingers crossed that it doesn't come back. To make sure, I run a tank of Shell 91 with my racegas every once in a while. Shell is supposed to have more cleaners in their gas, but the gas is crap for performance. I haven't had the code now for about a month. I am keeping my fingers crossed.
Not sure if this is related or not. I got the P0304 when I installed a Vishnu Stage 1 on my car. I lost 500 rpm of spool up. I went through all kinds of crap to figure it out. It turns out that I had a vacuum leak leading to the turbo, I think causing the slower spool. Anyway, I also got Samco hoses. So, I believe I had a vacuum/boost leak that is now corrected. The idle is better and I don't hear that miss at idle that I used to hear when I had the P0304 code. Plus the car pulls cleanly to 7800rpm now. Boost hits hard and strong.
I am going to add a fuel injection cleaner once a month just to make sure the injectors are working fine. Maybe I am being neurotic, but I think it will help. Hope this helps!
Old Jul 6, 2005 | 12:09 PM
DaveLC2's Avatar
I dropped my car off at the dealer this morning for the P0304 and they are doing a reflash as I type. The suspension noise turned out to be the upper control arm coming loose. All should be good again.
Dave
Old Jul 6, 2005 | 12:11 PM
zstryder's Avatar
Is this true? I always thought the Shell V-power was supposed to be pretty good...? I wonder if our 93 V-power is any different from your 91.
Old Jul 6, 2005 | 12:18 PM
revolagoy's Avatar
As far as 91 oct goes, I think Shiv said Pro Power 76 was the best. I think there is a thread Vishnu forum with dyno results. When I put in Shell 91, my gas mileage went down as well as performance. It isn't confirmed by the dyno, just the butt dyno.
Old Jul 6, 2005 | 12:23 PM
revolagoy's Avatar
Dave
Doesn't the factory flash stop your ability to get an aftermarket flash? I think it also erases your aftermarket flash if you have one. I didn't get the P0300 dealer flash because of this. Besides, I am not sure the dealer flash will help with an idling p0304 issue. I thought is was for the folks that were getting the 5th gear drive train noise p0300. Not sure I am correct on this.
Old Jul 6, 2005 | 05:22 PM
DaveLC2's Avatar
I really hope not because that's the 1st thing I want to do after getting a 160* Rally Art thermostat.
Dave
Old Jul 6, 2005 | 05:26 PM
zstryder's Avatar
Ah, we don't have 76 around here. Just Shell, Exxon/Mobil, BP/Amoco.
Old Jul 6, 2005 | 09:59 PM
revolagoy's Avatar
Dave
https://www.evolutionm.net/forums/sh...ighlight=p0300
Check this tread out. I would call Vishnu to confirm.
