280 idle help?
Old May 3, 2005 | 05:44 PM
Mistasparkle's Avatar
280 idle help?
Hey shiv i will have your stage 1+ with some goodies running your 1+ map soon. Any thoughts on idle performance and driveability?
Old May 3, 2005 | 06:55 PM
help?
Old May 3, 2005 | 06:59 PM
ez76's Avatar
FWIW, Ted B claims good idle with HKS280's with cam gears set +2/0.
Old May 3, 2005 | 07:01 PM
thank you
Old May 4, 2005 | 10:35 PM
erioshi's Avatar
I've had some HKS 280's in my car set at -2/-2. With my ported head the idle was very lopey; even with the new idle assist features in v3. Driveability was pretty good, but I did ocasionally get some very low RPM surging - slow parking lot stuff. On the throttle and crusing they ran well.
Old May 4, 2005 | 10:59 PM
housedj's Avatar
Thumbs up
HKS 280's will be easier to tune thatn the Tomei 280's since the lift isn't as high. idle can be tuned in though but will be tuff on a stock turbo.
Old May 5, 2005 | 12:03 AM
leif's Avatar
idle is fine. its obviously lumpy but what do you expect. even running a simple 1+ map off the net they'll idle right around 900.
Old May 5, 2005 | 07:45 AM
Ted B's Avatar
With the +2/0 cam setting, the car is very torquey, and I'm seeing about 30cm2 (11.8")vacuum at idle.
Old May 6, 2005 | 12:31 AM
erioshi's Avatar
I wasn't complaining about the idle or "lopeyness" at all - simply answering a question. I'm just fine with a lopey idle as long as the car has good tip-in and low rpm response when I do step on the throttle, and of course no stalling issues. The HKS 280s with v3 and the idle stability turned on met all those requirments.
Old May 6, 2005 | 12:47 AM
leif's Avatar
my post wanst aimed at you, i was answeirng the question as well.
Old May 6, 2005 | 10:14 AM
Vishnu_Evo8's Avatar
the sound of the idle is amazing... scares the hell out of people.
