Boost or fuel cut?
V3 Boost or fuel cut?
Well this is strange and I'm not even sure if it is either. This has happened a couple of times, but when going wot or close to wot in 4th gear around 4000 - 4500rpms my boost will sometimes just drop right down to 8 - 10psi then instantly climbs back up to normal boost pressure. Anyone know what this may be? I get no popped cell or anything. Sometimes timing feels like it is pulled, but no cell. Also I'm a stock evo equipped with only a XEDE.
Originally Posted by Dustin@Vishnu
Does the car have a violent hickup?
Originally Posted by donour
What's your altitude up there?
d
d
I'm stock and I know some people at high altitudes need a fuel pump, but only if they have a TBE.
Originally Posted by BLUEBYYOU8
check the clips on the front of the snorkle attached to the radiator mount sometimes they come lose and the snorkle will suck it self to the hood
Originally Posted by crusin_lancer
7000ft+
d
PS: I found a really great townhouse up in the NE heights -- enough garage space for the Evo, the WRX, _and_ extra parts.
Nice you should PM me the cross streets. Heights are great, a friend of mine lives in some townhouses between candeleria and commanche. Not to badly priced either.
On-topic:
Bump!
On-topic:
Bump!
d
Whoa, I'm pretty close to that. Juan Tabo x Montgomery is basically it. It's funny, the street/subdivision isn't even on any online maps. As a matter of fact, a lot of the places I looked at haven't yet made it onto google maps or mapquest.
d
d
You will be VERY close to a 101oct pump though. I believe it is on the corner of Juan Tabo and Indian School called "Premier Gas and Food". Just a tip.On-Topic:
Still need help with my problem
BUMP!
I have a similar situation with the latest V3 firmware. Typically this occurs in my case from a standing start and on the first shift the problem goes away.
What I find strange in both cases why does the boost pressure home in on ~9 psi. To be sure this isn't a fuel cut or anything similar.
I have tried the obvious mechanical things which leaves the Xede's boost control. If I had the older V1 firmware I would reflash to test if the problem goes away....
Comments anyone?
Comments anyone?
Comments anyone?
Comments anyone?
