View Poll Results: Do you use Meth/Alchy/Water Injection?
Yes
15
35.71%
No
27
64.29%
Voters: 42. You may not vote on this poll
How many people running Methanol/Alchy injection?
Old Jun 26, 2005 | 09:17 AM
shiv@vishnu's Avatar
Title says it all. Just want to see how many people here run Meth injection in their EVOs. And if so, do you use a MAP sensor to trigger it. If not, what do you use?
Shiv
Old Jun 26, 2005 | 10:52 AM
EVOtagger's Avatar
i want to run a setup, but i just dont know enough about it yet...i would like to learn though...hopefully some good info will turn up in this thread
Old Jun 26, 2005 | 11:48 AM
EvoTio's Avatar
Shiv, I am running a Aquamist 2D water injection set up. My pressure switch activates the pump at 10 PSI. The flow rate is controlled by a high speed valve that moniters/mirrors the #1 fuel injector. I will be seeing you here in So Cal for a custom tune at Tuning Technologies.
Old Jun 26, 2005 | 11:53 AM
Evoryder's Avatar
i run the snow performance unit in my evo...it's triggered by a boost pressure switch
Old Jun 26, 2005 | 12:02 PM
93civEJ1's Avatar
i wish i were running alky injection.
Old Jun 26, 2005 | 01:33 PM
Ludikraut's Avatar
I am not, nor will I be running alky injection.
l8r)
Old Jun 26, 2005 | 02:23 PM
Smogrunner's Avatar
I would love to use it if adequate safeguards were in place for both the engine and the driver. Damn, my car would be truly scary on methonal...
Old Jun 26, 2005 | 02:46 PM
midwestmonster's Avatar
Alkycontrol kit w/3bar map sensor
Old Jun 26, 2005 | 04:42 PM
EVOtagger's Avatar
Originally Posted by Smogrunner
adequate safeguards
this is what I would like more info on....what preventative safety measures can be taken and what system currently on the market offers the best rate of safety
Old Jun 26, 2005 | 05:09 PM
tcarretti's Avatar
WELL...... I've had a kit installed in my car for about 4-5 months now. As you know Shiv, I was the one suffering from a leaky nozzle when you came to Dallas to tune last time. Since then, I've gone to a standalone and will finally get tuned for the alcohol on July 9th barring unforseen circumstances. It'll be running on top of a White Rabbit turbo so hopefully it will make a good amount of difference over my current setup.
Funny thing is, if it hadn't been leaking and you had been able to tune it out that day, I probably would have never considered buying the turbo upgrade.
Go figure...........
Congrats on the new XEDE stuff by the way. If I had known it was coming I never would have switched over....... Water under the bridge now..... ECU is LONG gone and the XEDE is in very happy hands..........
To answer your initial question though.... it is a progressive controller that runs off of boost pressure........
Tony
Old Jun 26, 2005 | 05:10 PM
Noize's Avatar
EvoM Administrator
Same here. If I need an extra little burst, I'll switch maps and run race gas.
Old Jun 26, 2005 | 05:44 PM
smokedmustang's Avatar
I am installing the AMS kit tomorrow, with the TME turbo and 280 cams. I will be going to Dyno4mance on saturday July 2nd to dyno tune it. I had to go to GMparts direct to get the MAP sensor and "pigtail" dont know any more than that, but Andrew will have my info/dynoed Maps if you want to call him next sat. Use my car to take it to the edge!
Ludi wont use Alky injection probably because he has a bottle of "Jack" under his seat, and If he smells Alky in the car, he wont know if he has a leaky nozzle, or he just burped! too confusing I guess. Just kidding Ludi, is AMS done yet, and when is your strap-down? need to see numbers!
Old Jun 26, 2005 | 07:46 PM
Ludikraut's Avatar
Ha! If I have any bottles under my seat, they will be Erdinger Weissbier.
Car is pretty much done, but AMS' dyno took a crap a couple of days ago, so it won't be tuned until the end of this week
l8r)
Old Jun 26, 2005 | 07:51 PM
jman425's Avatar
I am running the aquamist 2c system but is having a hard time interfacing with the XEDE. I am currently running it off the injector duty cycle w/ pressure switch trigger until we can find a permanent solution.
Old Jun 27, 2005 | 04:00 AM
l8r)
Looks like we'll be on the dyno about the same time! it also appears we have the same taste in bier! after living 5 years in Germany (near Munich) and 5 consecutive Oktoberfests, I settled on the Hefe Weizen myself! Kudos to your taste!
