what is wrong?
Old Jul 10, 2005 | 09:12 AM
bigmike9726's Avatar
what is wrong?
i got my Xede a few months ago and custom tuned when you guys were down at turbotrix last. it has been great except the CEL was on, which i didnt care about until it was time for inspection. I left the car overnight at mitsubishi so the mechanic could do what he needed to get it to pass inspection. heres where the problem comes into play. the good news is the CEL is now off, but the bad thing is that on the drive home, there was a big loss in boost. i drove back later in the day to show the mechanic, but then the boost was perfectly fine. later in the day, however, it dropped back down. i turned off the car and then turned it back on, and the boost was back to normal...... what could be causing this????
Old Jul 10, 2005 | 09:33 AM
sr20det91's Avatar
They my have reset the ECU. Sometime it takes a day or 2 for things to get back to normal after that. I wonder if they did the P300 reflash and if that would have any effect on anything. I would ask the mechanic what exactly they did to the car.
Old Jul 10, 2005 | 09:36 AM
asasin79's Avatar
sometimes the xede won't activate...look at the status light when having the low boost issues i bet the light is flashing red. used to happen to me about 2-3 times/week.
Old Jul 10, 2005 | 02:14 PM
Dyno4mance's Avatar
yes, to avoid this make sure you key on for a few seconds before cranking, this should allow the xede to initialize
Old Jul 10, 2005 | 02:16 PM
asasin79's Avatar
yeah that's what i do. sorry for not elaborating. i was a little pressed for time earlier. i put the key in the on position and listen for the fuel pump and other systems getting primed then crank it. good luck.
Old Jul 10, 2005 | 02:31 PM
thanks for the responses guys, but if the xede doesnt initialize then wouldnt it no work from turning the car on? it seems to work fine when i first start it up, its just after a while then all of a sudden i lose boost?
Old Jul 10, 2005 | 02:54 PM
asasin79's Avatar
well when it happens to me i am limited to 10psi. the car starts and runs fine just limits boost. so you're driving along hitting full boost then all the sudden not able to hit full boost? or never reaching full boost from the time the engine cranked? seriously i used to have this problem 1 out of 10 ignition sequences. i installed a remote status led and learned to wait before cranking.
Old Jul 10, 2005 | 03:01 PM
KZEVO's Avatar
how are you able to tell that there is boost loss? Do you have a boost guage? If you do can you post before and after readings? Otherwise, when it happens, try what the others have suggested...see if the Xede light is green or red....it could be as simple as a harness problem good luck
Old Jul 10, 2005 | 10:26 PM
when i start the car its fine, its just after a while i notice a drop from 1.6mmhg to about .8. my mechanic thought it was a harness problem, but this didnt happen until he had to disconnect it in order for it to pass inspection
Old Jul 11, 2005 | 07:22 AM
asasin79's Avatar
so the mechanic disconnected the xede for it to pass inspection? sounds like he might've reinstalled it wrong. hell i passed here with a full stage 3 atmospheric wastegate and a test pipe. we just need safety inspection and obd2 scan. good luck. check to make sure everything is hooked up properly. could be the ground as your boost comes and goes.
