Need a little help with Xmap
Old Jul 21, 2005 | 07:42 AM
Evo23IG's Avatar
Well yesterday I did my firmware update for my V3 finally, lol. I tried using Xmap 3.0 at first and was not successful, so with Dustin's advice I used the Xupdate. But before I did that I had the downloaded and saved with the Xmap. So then I did firmware update with Xupdate everything ran smooth.
Do you have to reboot Xede after u finish update and how do you know that the process was done correctly?
Then I got the Xede back into boot mode and used the Xmap to upload the maps. After you upload the maps, it asks u to burn the maps to IIFROM (or something like that), Do you like yes or no?
My problem is I am getting a green light and but the car is boosting past 12 psi. What should I correct? When clicking on Xede information, it shows the map in the Xede.
Any help would be great, thanks in advance.
Old Jul 21, 2005 | 12:51 PM
gashero's Avatar
If it show the map in the xede then the map should be there. about your boost our car should boost pass 12psi and hopefully around 20-22 psi taper to 17-18psi.
Old Jul 21, 2005 | 01:25 PM
Evo23IG's Avatar
Its All Good With Dustin's Help Everyting Is Fine.
Old Jul 21, 2005 | 01:30 PM
xy2nickx's Avatar
is it possible that the boost wire came disconnected from the xede harness. Mine had done the same thing once.
