SMART Install Directions.
just got everything updated with the firmare and xmap 3.2....i don;t even have my smart stuff installed yet (meaning i have smart fuel and timing zeroed out) but it feels better at top end with the boost already...is this possible?
Still can't find the launch control in xmap yet though....help.
\hiv
Should be configurable....6400 is too high for the stock clutch.
I too have upgraded firmware and xcode but it still feels the same. I only did it for the launch controls. DA /\/\ /\/\ IT
From what I understand you can now tell the Xede what A/F you would like to maintain and it will do so. How do you do this? I see the SMART fuel table with some +4% to -2.3% values. What are these doing? How do they correlate to keeping an A/F, or do I not have the SMART activated? Basically, I guess some of us who have never tuned need some sort of instruction book on what we are looking at and what it does. Like if I input x in colum a what happens? If I but in x+2 what happens? How do we use this program? I know that the Vishnu guys see this as elemetry stuff, but I for one do not know how to make it work.
Don't touch the SMART tables unless there is a really good reason to. ALL of the tuning that you will be doing will be done through the normal Fuel, Timing and Boost tables. Just like before. Except now that you can monitor wideband signal and knock noise. The idea is to leave the SMART fuel and timing table alone and doing its own thing, all by itself. It doesn't need anyone help
Shiv
Shiv
I believe the reason you purchased SMART was so you wouldn't have to adjust those tables from the baseline maps. SMART should pretty much provide you with a custom tune above and beyond the baseline.
The only thing I am concerned about is relying on the health of a wideband sensor to prevent bad things from happening.
Shiv
I keep seeing launch control come up, is this the same thing as what they put in the newer MR's that allows it to hold a certain rpm when the throttle is floored with the clutch in in 1st gear? Or are we talking about the drive train busting launch at 10psi?
Thanks,
Sam
Thanks,
Sam
And if it is that way right now what have we done??? Please tell me I did not jack something up...
I drove the car to work tonight and the wideband says absolutely do not drive with it unpowered, so I do not have the option of just cutting the wire....
I noticed something today about the current dropping when the AC is switched on and off. It can cause the wideband to kick back into boot mode. So i am redoing the instructions to tap power off of a more dedicated source. And FWIW, the wideband can be run without power for short periouds of time. However, running it weeks on end with no power, may shorten its life.
