SMART XEDE Q/A here!
Originally Posted by joeycoates
So I probably need to move the zero's backto where they were in my SMART fuel table? Do you have what you would interpret as an ideal graph, just so we know what we are aiming for? Thanks
Cheers
shiv
Originally Posted by donour
AFRs. Explain 'em.
EDIT: Oh, and closed loop boost control: what's the deal?
d
d
1) Shoot for the zero line. It is conservatively rich on pump gas. But not excessively so. It can be leaned out a bit above 6000rpm but the gains wont be mind blowing. Keep it safe for you and follow the tune-up directions as they are released.
2) Every wideband unit is calibrated differently. If you installed 3 on the same car, they would all read differently. Sometimes alarmingly so. And if you put one on the tailpipe a la dyno tuning, it will read much leaner than if it were put in the downpipe. So talk nominal AFRs with a grain of salt when comparing them to other systems on different cars, using different sensors in different locations. The only important thing here is that the sensor we are using is consistent and quick acting (which it is).
As for closed loop boost control, is it under development. When its done, we can use that closed loop logic on other stuff as well. With the amount of things I'm throwing at the programmers, I'd be happy if it was done and ready for testing in 2-3 weeks.
More pressing matters that we are attending to is getting the datalogs and display to show useful values (actuals degrees of total retard, load %, AFR/Lambda) since this would take one step out of the tuning-thru-datalogging practice.
Another feature we are working on RIGHT NOW is the abilty to set conditional outputs:
This would relieve us of having to use full tables to turn things on and off (launch control, fuel threshold, leanrun protect, overboost protect, etc,.) This would free of some space and give us more memory for more tables.
Cheers,
shiv
Originally Posted by shiv@vishnu
What would you like to know specifically?
EDIT: Will the Creader get rid of my P0420 error? I want to remove the second 02 sensor and just install the wideband there (no cat).
You answered the question in your AFR response. I just want the datalogged numbers to be translated to useful units. Also, a range of knock values that would be considered bad would be nice.
It's got an o2 simulator built in. We just haven't told anyone about that yet
shiv
Will my displacement increase and head work cause any problems, or will the table remain the same?
Shiv
Cool, that is about where I was and it was runnign pretty well I think...
Actually, I put the SMART fuel table back to where it was originally and knock seemed to increase? There were no signs of knock when it was running a little bit leaner.
Thanks for the help!
Alky Injection/Launch Control Question!!!
The launch control table pulls all fuel sources at the set limit, or only Gasoline?
That question should be enough to let you know where I'm going with this, but for everyone else....
If the LC table only pulls the gasoline at the set RPM, wouldn't the Alky still get injected which in effect would nullifying the rev limiter and allow the engine to continue to rev albeit lean?
- Steve
- Steve
Fuel Threshold Question
Do you have to fill this table with -100 along with zeroing out the SMART Fuel and Timing if you will not be using the SMART features?
I noticed after we hooked up the Launch Control/NLS feature we lost some boost and I had to compensate by adding more boost in the boost table. This normal?
Shiv
- Steve
- Steve
So, if you chose to use Methanol in your system, cut back -100%. This may end up meaning that say, 70% of the fuel is cut.
If you aren't using Meth, you can even experiment with cutting back less fuel. Instead of -100%, try -50%. Heck, you might even want to try tapering to adjecent columns to acheive the desired hysteris/misfire behavior. So instead of going BAM BAM BAM, it will go BAM BAM BAM. Just try it out during launch conditions first before testing during WOT shifting conditions, of course
Cheers,
shiv
you shouldnt have to zero out the smart fuel or timing if you dont have the equipment yet...you should only have to set -100 values on the fuel threshold table...this will prevent the smart fuel table from working at all
and i dont think the SMART timing table really matters if you dont have the knock buffer hooked up since the SMART wont be able to hear knock at all so no adjustments will be made
im running mine without the SMART hardware with only the fuel threshold table zero'd out with -100 values and it runs great
