Have installed SMART, now no boost control
Old Aug 16, 2005 | 09:06 PM
Zarathustra's Avatar
So here's what I did yesterday:
-welded bung onto downpipe
-flashed XEDE firmware to v3.2
-used SMART template, zeroed out SMART timing & fuel, changed boost to my old settings
-wired knock buffer and wideband into XEDE harness
-installed bleeder tube (under airbox, connected 2 vacuum lines together that were connected to boost solenoid as per instructions)
Note - o2 sensor not installed yet, XEDE shows green light
Here's my problem, I now have no boost control. If I zero out my boost table, I still peg my boost gauge. I'd assume its from the bleeder tube, but I did it exactly like others have in this forum. Any ideas?
Old Aug 16, 2005 | 09:13 PM
asasin79's Avatar
the vacuum lines don't connect to each other...that is for xflashed non xede cars.
Old Aug 16, 2005 | 09:36 PM
Dustin@Vishnu's Avatar
Make sure you didn't knock off any boost lines when you removed downpipe. If the table is zeroed, and you are still making enough boost to peg the gauge, something is happening with your mechanical spring pressure.
I would check for cuts in the lines, a crimped line, or a removed line.
Old Aug 17, 2005 | 05:36 AM
gsujeff55's Avatar
definetely sounds like a vac hose issue. the bleeder is just supposed to go "inline" with the vac hose that runs from the solenoid to the "T" coming off the wastegate/boost source
Old Aug 17, 2005 | 05:23 PM
Everything I read on the bleeder was to completely disconnect the tubes from the solenoid and then connect them together with the bleeder. So its supposed to run inline with the line that has the brass fastener on it, with both lines still running to the solenoid?
Old Aug 17, 2005 | 06:49 PM
asasin79's Avatar
yes the bleeder goes inline on the hose oposite of the one that feeds to the maf pipe. the insturctions you read are for xflashed cars.
Old Aug 20, 2005 | 01:18 PM
Originally Posted by asasin79
the insturctions you read are for xedeflashed cars.
I assume you mean XFlashed. Anyway that fixed it, thanks!
Old Aug 20, 2005 | 01:20 PM
asasin79's Avatar
oh yeah...sorry don't know what i was thinking. yes for cars without an xede.
