XEDE keeps dumping maps...
Old Sep 13, 2005 | 09:50 PM
aresix6's Avatar
Okay, just got my XEDE installed the other day and I also got a base map from Sackett that I uploaded to it. Everything works fine for 2 days, then I start getting the car acting irradic one evening. When I look at the XEDE itself, the LED is red (not amber, but red). It is doin crazy stuff with the boost. Well, I take it easy and get home to hook the laptop up to it. Well, lo and behold, there is no map loaded to it (yes, I did do the upload as well as the burn). Well, I uploaded the map again and everything worked fine, until tonite, when I started comin home it started doin the same thing. I hooked up the laptop and..viola, no map in XEDE. I've loaded it up again and it's fine for now (the map is awesome, BTW). But I don't want to have to have my laptop constantly hooked up. Is there something I did wrong in the install? In the firmware update? Some kinda save feature I'm not doin right?
Anyway, please help...
Thanks...
BTW, I can't seem to indentify any consistant action that creates this anamoly...
Old Sep 13, 2005 | 10:12 PM
Sackett's Avatar
hey,
are you uploading (ctrl-u) and burning (ctrl-b) the map? it should go through two processes.
also, turn the key to 'on' for a couple seconds before cranking and starting the car, giving the map time to load.
Old Sep 13, 2005 | 10:15 PM
Jaylenospoolboy's Avatar
Is there anything with a magnetic field in your glove box?
Old Sep 13, 2005 | 11:28 PM
aresix6's Avatar
yes, I do the uplaod and burn process. No there is nothing near the XEDE out of the ordinary. I do wait for a few seconds, but even when I just put the car in the "ON" position, the amber lite blinks, which means that there is no map loaded in the XEDE
Old Sep 14, 2005 | 01:19 AM
eling99's Avatar
isnt the flashing orange light good?
xede is waiting to detect a timing input signal. this happens before the car is started?
so does this mean there is no map?
Old Sep 14, 2005 | 05:25 AM
aresix6's Avatar
from what I've been told, yes, that is what that means. When the map is loaded correctly, it usually starts in amber for a quick second then goes to solid green.
Anybody?
Old Sep 14, 2005 | 06:27 AM
asasin79's Avatar
green will not come on until you start the car.
Old Sep 14, 2005 | 10:30 AM
eling99's Avatar
k..thats what i thought!!!
Old Sep 14, 2005 | 09:38 PM
sr20det91's Avatar
aresix6, what map are you using??
Old Sep 15, 2005 | 03:07 PM
aresix6's Avatar
oh, I'm usin a Map that Sackett passed onto me. He used an 03-04 base map for Cali 91 pump gas, but has tweaked it a little. It's workin fine for me right now until I really learn how to use XMap better ..I'm still new to this tunin stuff.
BTW, I called Vishnu and talked to Dustin. He said I may be one of those rare cases of a bad EEPROM, but before I send it to him I tried updating the firmware again. So far it seems ot be holdin up, but I got my fingers crossed...
