creader question
Old Oct 10, 2005 | 09:50 PM
aresix6's Avatar
creader question
OKay I had the Smart w/ my XEDE and I finally got the creader in. A few questions on the install. I haven't had a code thrown yet, but I guess it's a good diagnostic tool to have anyway. Well, whenm installing it, is it to be installed at all times? or just when a code is thrown? Right now, with the car off, I get the LAUNCH, 1,2,3, then it hesitates for a bit then 4,5 then I get the letter "E", then it starts the cycle all over again. IS it supposed to do this all the time? It just keeps goin...unless I am only supposed to be installing this when I recieve an ECU code...
Thanks
Old Oct 10, 2005 | 11:20 PM
Jaylenospoolboy's Avatar
If it does that all the time it is FUBAR. You should send it back and get a new one.
Old Oct 11, 2005 | 01:14 AM
isaac@vishnu's Avatar
Sounds like you have a defective Creader. We had a batch of bad CReaders, unfortunately we found out after we sent them out. If you mail us your defective CReader, we'll replace it.
Old Oct 11, 2005 | 05:05 AM
sandm's Avatar
I plugged mine in the car this am. it says launch, then has a bar like this "_" on each one of the led sections, then goes to an "e" in the far left corner. I haven't thrown a code yet, just testing to see if it works. does this mean that mine is dead as well?
Old Oct 11, 2005 | 05:36 AM
aresix6's Avatar
yeah, that's crazy, cuz I know the whole deal about the bad creader batch...that's why I've had the Smart setup w/o it for so long, was just waitin on it, well I got one in yesterday cuz I know Isaac was sendin em out. I thought this was finally under control?
Old Oct 11, 2005 | 03:46 PM
ok a working C-Reader should look like this.
LAUNCH -1- -2- -3- pause -4 - -5- pause E then cycles though again.
On the 05's it will constantly be on, the 03-04's i think the CReader turns off when the car is off.
aresix6: sorry i read yours kinda fast, your CReader sounds like its working just fine.
A bad CReader will do otherwise.
Old Oct 11, 2005 | 07:38 PM
Sackett's Avatar
No, that is a NONWORKING creader. the E means "No Communication"
A WORKING CReader will do the following (strait from the manual): Display [LAUNCH], followed by the trouble codes (if any). If there are no trouble codes, [- - - -] will be displayed.
Old Oct 11, 2005 | 08:03 PM
Cajun Power's Avatar
OMG can we call the manufacturer now!
Old Oct 12, 2005 | 01:18 AM
That is how my CReader reads and it was still able to read codes. So I assume it works. I will talk to Dutin in the morning.
Old Oct 12, 2005 | 06:28 AM
freedom's Avatar
This is such a painful thread to read I just have to comment....
If the car (ECU) is OFF the Creader will exhibit "LAUNCH -1- -2- -3- pause -4 - -5- pause E" and then cycle though again. This is because the Creader cannot communicate with the ECU when it isn't powered on and normal behavior.
If the car is ON you will get something similar but NO "E". Clearly in this case the Creader is communicating with the ECU.
On the other hand if the Creader comes up with an "E" and the car is running then you need a replacement Creader.
With respect to 03-04 versus 05 cars I can only comment on the 03 car. The Creader will be powered at ALL times given that the OBD-II socket is powered directly from the battery. For reference refer to the shop manual's schematics.
There has been so much confusion on how the Creader should work maybe Vishnu needs to update their document.
Old Oct 12, 2005 | 04:14 PM
sandm's Avatar
mine does "launch - - - pause - E" so I need a new one????(the - represent one line of the display lighting up, I have never had numbers show up)
vishnu, how do I go about gettin one???
thanks
Old Oct 12, 2005 | 04:42 PM
Dustin@Vishnu's Avatar
Yes, you need a new one. Please send us yours, and we will send one back out to you.
thanks
Old Oct 12, 2005 | 05:51 PM
sandm's Avatar
vishnu rocks...
Old Oct 12, 2005 | 07:12 PM
Sackett's Avatar
My 05 is powered at all times also. So there you go.
Old Oct 13, 2005 | 10:11 AM
Turbo-Ron's Avatar
Do the 05 Evo's have P0300 issues as well?!?!?!?!!
