creader question
Old Oct 13, 2005 | 10:27 AM
shiv@vishnu's Avatar
Originally Posted by Turbo-Ron
Do the 05 Evo's have P0300 issues as well?!?!?!?!!
Not inherently like many 03s but a CReader is needed if you want to run the positive smart timing advance offsets that make the car feel really good. With such timing gymnastics, a CReader-less car may through the aforementioned code.
Shiv
Old Oct 13, 2005 | 05:58 PM
Ludikraut's Avatar
Originally Posted by freedom
With respect to 03-04 versus 05 cars I can only comment on the 03 car. The Creader will be powered at ALL times given that the OBD-II socket is powered directly from the battery. For reference refer to the shop manual's schematics.
Yep, after about 30-60 seconds my C-Reader even manages to turn off the "diagnostic" check engine light. (read: as in when the key is in the ignition, but the engine is not running, which is when all of the idiot lights are on to make sure they work). Pretty weird.
I don't suppose that there is a version of the C-Reader somewhere that does not constantly cycle through the codes? I'd like to mount mine in spot where I can see it, but the constant cycling of test codes might drive me insane.
l8r)
Old Oct 14, 2005 | 04:04 AM
freedom's Avatar
Try it again without the Creader. My car turns off the "diagnostic" check engine light after 30-60 seconds without the reader in place.
l8r)
Old Oct 14, 2005 | 06:48 AM
Ludikraut's Avatar
Heh, I guess I was so used to looking at that P0420 CEL, that I never noticed.
l8r)
Old Oct 14, 2005 | 09:52 AM
ruzs's Avatar
Creader
If the Creaders stay on when the car is turned off, will this not run the battery down? That means we have to unplug it every time we stop? That does not seem like the perfect solution.
Sigfrid
Old Oct 14, 2005 | 10:13 AM
oneEVO8two's Avatar
what in the hell is a C-reader?
Old Oct 14, 2005 | 10:15 AM
Dustin@Vishnu's Avatar
FWIW, I have had my c-reader plugged in for over 4 months now. I havent had any problems. Do realize that your ECU stays powered when the car is off, as do many other things. Being that the current draw is so low, I dont foresee it causing any more of an issue than the ecu draw off of the battery. I would only unplug the C-reader if you are leaving the car sit for awhile. (like a whole season, which you should prep your car for anyways.)
Sigfrid
Old Oct 14, 2005 | 10:24 AM
The EVO will do this without the CReader. Try it
Shiv
Smogrunner
Jun 26, 2017 03:54 PM
Charles B.
Jul 15, 2009 03:18 PM
Jedi_Gill
42
Oct 11, 2007 12:22 PM
deadbeatrec
25
Oct 10, 2007 08:03 PM
MYFIRSTEVO
12
Oct 18, 2005 05:12 PM
