Another launch control thread...
Old Oct 17, 2005 | 06:05 AM
gsujeff55's Avatar
i don't have smart....
how do you find something like that out? launch control used to be on the top of the list, until we got a make-shift one taking up a map....
lets not settle for 'par'.
Old Oct 17, 2005 | 10:19 AM
Dustin@Vishnu's Avatar
Please don't feel that it is make shift. It is a fully working solution. However, It seems that many don't know how to use it properly, which is why further development is being requested. Like I said, we are not done developing evo xedes, but we do have a development line up, which we have to follow. We will do our best to squeeze this in. We have a lot of really smart guys on our forum, and the more help we can get from you, the faster we can get it up and rolling. The shop manual has sensor info.
Old Oct 17, 2005 | 10:50 AM
gsujeff55's Avatar
i know how to use it, the car doesn't like it. you either have to launch at at really high RPM so the NLS works, or you have to not use the launch control and have a NLS.
we were supposed to have something that was a toggle on/off type of an option, not something taking up a map....remember?
just trying to motivate you guys, i know you are busy....but i have no clue how to test/try something like this.
Old Oct 17, 2005 | 10:54 AM
You can toggle it on and off with a switch on the clutch wire.
Old Oct 17, 2005 | 11:38 AM
gsujeff55's Avatar
i know, im doing that!
but, i can no longer run 2 maps because of it.
Old Oct 17, 2005 | 11:42 AM
gsujeff55's Avatar
*edit
Old Oct 21, 2005 | 09:23 AM
shiv@vishnu's Avatar
Ok.. i'm working on how to make the launch control and NLS have two different RPM triggers. What will probably happen is that the launch control will be a 1 time only act. That is, it will only work ONCE right after a map switch. After that one launch, it will disable, leaving only NLS working. Would that be suitable for most peoples needs?
Shiv
Old Oct 21, 2005 | 09:27 AM
Jeff_Jeske's Avatar
How do you reset the brain to tell it its the first launch again?
Old Oct 21, 2005 | 09:53 AM
isaac@vishnu's Avatar
Just do a map switch (toggle back and forth).
shiv
Old Oct 21, 2005 | 11:32 AM
Vishnu_Evo8's Avatar
that woudl be nice..
Old Oct 21, 2005 | 01:26 PM
gsujeff55's Avatar
IM sorry, i don't quite understand. Are you saying we will have to toggle to another map to have the launch control active again? How is that gonna work, as we can only fit one big map on the xede?
Also, is it going to be possible to not have a NLS at all this way? Like, be able to have launch control set up at 5500 or whatever, then immediately disabled for the rest of the run?
is it not possible to use the speed signal? or just too tough to find out?
Old Oct 21, 2005 | 01:29 PM
Jeff_Jeske's Avatar
I dont understand the map switch either. It definately would be better to have this function rely on speed. I would hate to have to flip a switch at every stoplight.
Old Oct 21, 2005 | 01:34 PM
Cajun Power's Avatar
Or a shiny red button on the left side of the streering wheel.
I would actualy consider putting a small momentary contact button on the back of the steering wheel on the plastic cover back there. One you could reach with your fingers.
Contact (closed)=Launch/NLTS enabled
open=not enabled
Old Oct 21, 2005 | 01:39 PM
It has to load tables from flash memory. It works just like a router. With out the memory dump upon power-up the Xede wouldn't know if it was a toaster or an Xede. You get two map blanks you just have to decide which one you want when you start the car.
Old Oct 21, 2005 | 01:42 PM
gsujeff55's Avatar
open=not enabled
descent idea. i feel like i have 1000 things to think about at the line already, sort of a PITA in that respect....but, if you could have a hold down on/not held down off type button that would be kinda cool.
