Stage 3 Installed....not tuned yet
Old Nov 13, 2005 | 08:53 PM
Jaylenospoolboy's Avatar
Originally Posted by scorke
Thanks for all the posts guys, you do not know how reassuring it is to have you guys backing up the numbers I have now. It is running very nice, its making 20 psi by 4k, which seems very high. I am still running a MBC and I was told that this could be part of the problem with spoolup, with the configuration I am running now Doug from Topspeed said some spool up could be recooped by running a EBC which he said would allow the wastegate to sense pressure change faster I believe? I was also told I could pick up some spool by switching to a different/more efficient intercooler? I feel like this is opposite thinking to what I believed when moving to a larger core, somebody please tell me I'm wrong.
Racegas tune will happen before too long, hopefully a intake manifold and front mount will be on there by then, my goals are 420 on pump and 500 on race gas.....
Scorke
Re: Spool, the stage 2 hit 36 psi on race gas in 5th gear by 4000 rpm. That was with a huge Nisei intercooler. Yours should be right there.
You should be able to get close to 500 on c16. The 420 on pump might be a little high, but maybe with headwork and 280's it could be possible.
Old Nov 14, 2005 | 04:12 PM
ct9a gsr's Avatar
Sam Corke, I have called you several times and TopSpeed has called you several times, emailed you, and sent you PM's.
Please pay for my injectors that you used while you were at TopSpeed. It is very hard to get a hold of you and I would like for us to settle this ASAP. Thank you.
Old Nov 14, 2005 | 05:15 PM
Vishnu_Evo8's Avatar
i think with his 94 octane he could make 420 on pump.
